Results 291 to 300 of 370
- Sep 2013
- 23
November 8th, 2017 07:20 AM #291Mga sir,
How about po sa CIVIC 2005 AT meron po ba kayo alam? meron kc problem saken, nagdedelay reverse ko mostly pag malamig mkina or morning...pag gusto ko kumagat need ko apakan gas and rev ng around 3000rpm... mkukuha pa kaya yun mga boss sa dialysis? saan po maganda mag pa dialysis ng Honda?
ito details ng car ko mga boss:
Honda CIVIC 2005 dimensional
Matic transmission
KM: 192k
Reverse problem and transmission slipping.
thanks in advance mga boss
November 8th, 2017 01:22 PM #292
Sir, i had experienced before the reverse problem as you had described in my Nissan Sentra Series III. After ilang weeks lang totally nawala na cya, as in ayaw na umatras ng sasakyan. Symptom of failing transmission na yan, particularly sa clutch pack ng reverse gear. Nag try pa ko i-change ATF (although di dialysis method), wa-epek din. Sayang nga eh kasi yung forward gears wala ni isang problema, ang ganda pa humataw sa Drive.
Bottomline, palit ako surplus AT.
- Sep 2013
- 23
November 8th, 2017 01:24 PM #293Saken naman boss mag 1year na ganito.. Minsan kumakagat agad..pero mostly nagddelay kagat unless pwersahin ko tlaga mag gas
Sent from my A1601 using Tsikot Forums mobile app
- Jan 2017
- 11
November 10th, 2017 04:38 PM #294question po mga boss on changing ATF, newbie here. My car is 1999 Lancer GLXI A/T, 4G92 engine:
1. pag nagpapalit ba ng ATF necessary pa yung flushing? O kahit drain and re-fill lang ok na?
2. pag nag-dialysis ba kailangan din ba palitan yung transmission filter (not sure kung yun nga yung tawag dun)
3. Ano pong compatible ba ATF for 1999 Lancer GLXI A/T, 4G92 engine? Sa ibang forum kasi sabi Mitsubishi ATF SP III, some say DiaQueen SP III... not sure kung alin dun, at kung pareho lang po ba yun ?
Thanks po in advance!
- Nov 2017
- 2
November 17th, 2017 08:23 PM #295Guys need advice po..nag pa change atf po kasi ako ng toyota altis 08 10th gen ang nakalagay sa manual atf ws pero ang nilagay ng mechanic atf t-iv..pwede po ba yun?
- Jul 2012
- 31
November 18th, 2017 04:56 AM #296hi! ask ko lang baka meron dito naka toyota revo 2000 glx model na nagpalit na ng atf. kasi yung sa amin, nag palit last july 2017 at 113,180 kms (pull down oil pan and throttle body, as per my nephew, as per mekaniko). then this week, pinalitan ulit kasi hindi na mag shift or hirap na mag shift (not sure kung 2nd or 3rd gear). then nung pinalitan, ma itim na ulit yung fluid. kaya ba maitin at hindi mag shift bcoz hindi na drain lahat ng atf? any idea kung ano ang tamang atf (type or grade) para sa revo 2000 at kung ilang liter? i already emailed toyota bicutan, pero wala pa sila reply.
thanks in advance.
November 18th, 2017 05:10 AM #297
before july 2017 when was the atf replaced?
if the atf fluid is dark it needs a another atf change. it should be red.
- Jul 2012
- 31
November 18th, 2017 05:13 AM #298
November 18th, 2017 05:25 AM #299
so 15years plus and walang atf replacement?
try another atf change if its dark...
- Jul 2012
- 31
November 18th, 2017 05:44 AM #300
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
