Results 251 to 260 of 370
August 10th, 2017 08:09 AM #251
August 10th, 2017 08:13 AM #252
August 10th, 2017 10:27 AM #253
August 10th, 2017 10:32 AM #254
I still like having the pan dropped just to see if there are any metal bits or gunk on the filter. I wouldn't want those things floating around and getting stuck on other parts during dialysis. So I alternate between dropping the pan and getting a dialysis.
- Aug 2017
- 61
August 10th, 2017 10:49 AM #255NL FR EN ru it
OIL FINDER
PASSENGER CARSTRUCKSAGRICULTURAL/CONSTRUCTIONINDUSTRIAL2T & 4T ENGINEMARINEGREASESADDITIVESCAR CARE PRODUCTSSPRAYS
HOMEOILFINDERABOUT ARDECANEWSBECOME DEALERCONTACT
[http://www]
[http://www]
OIL FINDERTHE BEST OIL FOR YOUR ENGINE
MATIC S-41
[http://www]
Synthetic all-round low viscosity Automatic Transmission oil
MATIC S 41 is a synthetic automatic transmission oil, which has been especially developed for automatic gear boxes requiring low viscosity ATF. MATIC S 41 ensures easy shifting under all operating temperatures, without unnecessary friction. Because of the low pour point and the high VI, MATIC S 41 can be applied in a wide temperature range.Because of the excellent oxidation and thermal stability, MATIC S 41 keeps its unique properties, so it easily meets the prescribed drain intervals. A unique combination of synthetic base oils and state-of-the-art additives, guarantee all-round, easy shifting. The low viscosity ensures a fuel economy benefit compared to conventional viscosity ATF's.
[http://www] PERFORMANCE LEVEL
BENTLEY:PY112995PABMW: 8322 2152426BMW: 8322 0144137BMW: M-1375.4 (8322 0142516)HYUNDAI: 040000C90SGMERCEDES BENZ 236.12MERCEDES BENZ 236.14MERCEDES BENZ 236.41Mitsubishi SP-IV & ATF J-2NISSAN MATIC - SSAAB 93 165 147TOYOTA WSJWS 3324GM DEXRON VIJAGUAR: Fluid 8432FORD MERCON LV & SPLAND ROVER: TYK500050MASERATI: 231603VW: G 055 005 A1/A2/A6VW: G 060 162 A2MAZDA FZHONDA DW-1KIA / HYUNDAI SP-IV/ SPH-IVZF Lifeguard Fluid 6 (S671 090 255)ZF Lifeguard Fluid 8
Download MSDS-fileDownload TDS-filePrice request
[http://www] FEATURES
Anti-wear protection : significantly extended transmission life.
Frictional properties : very smooth gear shifting, no vibration.
Extended oil life : excellent thermal and oxidation stability.
[http://www] APPLICATIONS
Mainly intended for the 6 or 8 speed automatic transmissions from ZF or other manufacturers, as fitted in BMW, Jaguar and Land Rover, it is also suitable for other OEMs, who recommend this type of fluid like Mercedes Benz, Hyundai, Toyota. This transmission oil is very universal in use.
[http://www] CHARACTRISTICS
Density at 15 °Cunitkg/laverage value0.845Viscosity 40 °Cunitmm²/saverage value31.0Viscosity 100 °Cunitmm²/saverage value6.2Viscosity Indexaverage value153Flash Point COCunit°Caverage value210Brookfield viscosity at -40 °CunitmPasaverage value9500Coloraverage valueAMBER
[http://www] PACKAGING
[http://www][http://www][http://www][http://www]12x1L20L60L210L
[http://www]
[http://www]
tales.be
Sent from my SM-J700H using Tsikot Forums mobile app
- Aug 2017
- 61
August 10th, 2017 10:51 AM #256NL FR EN ru it
OIL FINDER
MATIC S-41
 PERFORMANCE LEVEL
 FEATURES
 APPLICATIONS
 CHARACTRISTICS
 PACKAGING
12x1L20L60L210L
tales.be
- Aug 2017
- 61
- Aug 2017
- 61
- Aug 2017
- 61
- Feb 2015
- 174
August 10th, 2017 12:38 PM #260Thanks for the input. Yes I'm sure that they know it's a M/T.
Nasa records naman nila and same casa ako nag papa pms eversince.
As per booklet, 60k kms or 3yrs whichever comes first. Ang concern ko lang talaga is advise nila na need daw ng dialysis.
Sent from my SM-G532G using Tsikot Forums mobile app
high idle RPM at engine start
