I’m having issues with the a/t tranny of my Toyota Vios Gen 3. Dati rough shifting from 1st gear to 2nd gear. Ngayon ok na. smooth shifting na kahit wala akong ginawa. Kaso it wont shift naman to 3rd gear. So now plano ko ipa dialysis. Kung di makuha baka palit tranny or rebuild.
I need to use Toyota ATF T-IV. Kasong ang mahal. 1.2k per liter. Ano kaya ang magandang alternative na brand if I wont use toyota atf?
Pwede kaya yung Mag1 na fully sythentic? It’s at P500. Way cheaper than using toyota atf. And mga ilang liters kaya ang kailangan?
Hope you can help.
Sent from my SM-J730G using Tapatalk[/QUOTE]
Pwede ka naman gumamit ng ibang ATF brand basta ang specs ay ayun sa requirement. Baka parehas lang yan ng rated SP-IV ATF.
Sent from my NX549J using Tsikot Forums mobile app
[/QUOTE]
Research mo kung yung Mag1 atf meets toyota T-IV. If it does, pwedeng pwede sya instead ng napakamahal na toyota atf.
Edit: heres a link of the mag1 site. Compatible sa toyota T-IV
MAG 1(R) Full Synthetic Multi-Vehicle Transmission Fluid
[/QUOTE]
That's pricey. I bought my T-IV at 446 per liter. Toyota Marikina.
Sent from my EVA-L19 using Tsikot Forums mobile app
Thank you mga boss. Hanap ako sa ibang branch. Grabe ang mahal dito.
Back up ko na lang yung Mag1 kung wala talaga.
Nagkaka problema ka na sa transmission, ititipid mo pa yung ATF...
Not a smart idea I think...[/QUOTE]
+1
Magkano lang ang price ng genuine Toyota ATF as compared sa transmission overhaul?
Mga sir,
How about po sa CIVIC 2005 AT meron po ba kayo alam? meron kc problem saken, nagdedelay reverse ko mostly pag malamig mkina or morning...pag gusto ko kumagat need ko apakan gas and rev ng around 3000rpm... mkukuha pa kaya yun mga boss sa dialysis? saan po maganda mag pa dialysis ng Honda?
ito details ng car ko mga boss:
Honda CIVIC 2005 dimensional
Matic transmission
KM: 192k
Reverse problem and transmission slipping.
thanks in advance mga boss
Sir, i had experienced before the reverse problem as you had described in my Nissan Sentra Series III. After ilang weeks lang totally nawala na cya, as in ayaw na umatras ng sasakyan. Symptom of failing transmission na yan, particularly sa clutch pack ng reverse gear. Nag try pa ko i-change ATF (although di dialysis method), wa-epek din. Sayang nga eh kasi yung forward gears wala ni isang problema, ang ganda pa humataw sa Drive.
Bottomline, palit ako surplus AT.
Saken naman boss mag 1year na ganito.. Minsan kumakagat agad..pero mostly nagddelay kagat unless pwersahin ko tlaga mag gas
Sent from my A1601 using Tsikot Forums mobile app
question po mga boss on changing ATF, newbie here. My car is 1999 Lancer GLXI A/T, 4G92 engine:
1. pag nagpapalit ba ng ATF necessary pa yung flushing? O kahit drain and re-fill lang ok na?
2. pag nag-dialysis ba kailangan din ba palitan yung transmission filter (not sure kung yun nga yung tawag dun)
3. Ano pong compatible ba ATF for 1999 Lancer GLXI A/T, 4G92 engine? Sa ibang forum kasi sabi Mitsubishi ATF SP III, some say DiaQueen SP III... not sure kung alin dun, at kung pareho lang po ba yun ?
Thanks po in advance!
Guys need advice po..nag pa change atf po kasi ako ng toyota altis 08 10th gen ang nakalagay sa manual atf ws pero ang nilagay ng mechanic atf t-iv..pwede po ba yun?
hi! ask ko lang baka meron dito naka toyota revo 2000 glx model na nagpalit na ng atf. kasi yung sa amin, nag palit last july 2017 at 113,180 kms (pull down oil pan and throttle body, as per my nephew, as per mekaniko). then this week, pinalitan ulit kasi hindi na mag shift or hirap na mag shift (not sure kung 2nd or 3rd gear). then nung pinalitan, ma itim na ulit yung fluid. kaya ba maitin at hindi mag shift bcoz hindi na drain lahat ng atf? any idea kung ano ang tamang atf (type or grade) para sa revo 2000 at kung ilang liter? i already emailed toyota bicutan, pero wala pa sila reply.
thanks in advance.
before july 2017 when was the atf replaced?
if the atf fluid is dark it needs a another atf change. it should be red.
so 15years plus and walang atf replacement?
try another atf change if its dark...
