Results 271 to 280 of 370
August 12th, 2017 11:02 AM #272
- Oct 2015
- 99
August 12th, 2017 12:43 PM #273
August 12th, 2017 01:24 PM #274
- Aug 2017
- 3
August 12th, 2017 02:24 PM #275
August 15th, 2017 10:42 AM #276
Dayuhin mo sir sa Exalta banawe 600 lang ang labor. Mag source ka na lang din ng 12 to 14 liters ng Castrol Transmax * 330 per liter sa mga auto supply. Kasama na dun yung pang flush. I think di naman ganun karami na 12 liters ang pang flushing pa lang kung via dialysis naman kasi makikita mo naman sa machine kung brand new na yung nahihigop niya. Di pa maganda kung ibang ATF pa yung gagamiting pang flush.
Take ko naman sa drain and fill method ka sa ATF eh kahit mga 3 drain and fill method ka, di pa din 100% brand new ATF yung nasa loob ng tranny mo. Much better kung palit ATF filter and dialysis method ka.Last edited by jmpet626; August 15th, 2017 at 10:46 AM.
- Aug 2017
- 232
September 4th, 2017 05:30 PM #277
September 4th, 2017 06:16 PM #278
Depends on the ATF they are using. Also, double check with the owner's manual on the applicable ATF specifications for your Innova before agreeing to the offer of the mechanic. Try to ask how much for labor only then you supply the fluid for the process.
If the car is fairly well maintained (no issues with the transmission and the fluid has been replaced as required by the maintenance schedule), then a standard drain and refill is okay.
- Jul 2016
- 17
September 12th, 2017 02:29 AM #279Mga sir ask ko lng po kung ano pinaka maganda gawin sa car when it comes to changing ATF? I owned a lancer 97 glxi AT, running at around 174+++ kms na. second owner na ako. Wala naman issue with the tranny kaya lng hindi na mahanap ng previous owner yung service record ng car. Last time I checked e dark colored na ung fluid sa dipstick. Advised ng isang mechanic sa gasoline station ay drop pan lang daw ayus na. Pero gusto ko sana malinis entire tranny ko. So ayun, still can't decide kung ano gagawin ko. I read here somewhere na mas advisable daw sa old model car ay drain and refill na lng instead of the dialysis process. Please help. Inputs will be highly appreciated.
More power!!
September 12th, 2017 03:31 AM #280
why did you wait til the color changed?
you can drop the pan if there is a replacement trans filter available.
drain and fill works fine and i would do it twice if the color isnt like new...
Can Changing your Transmission Fluid Cause Damage? - YouTube
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; September 12th, 2017 at 03:35 AM.
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
