Results 301 to 310 of 370
November 18th, 2017 06:18 AM #301
use same type and grade.. im not sure which type though.
- Aug 2017
- 232
November 18th, 2017 07:26 AM #302
- Jul 2012
- 31
November 18th, 2017 07:31 AM #303
- Aug 2012
- 2,767
November 18th, 2017 07:44 AM #304ATF WS is not compatible to ATF T-IV. You should use Toyota ATF WS or Multi-vehicle ATF that is compatible to ATF WS. Read the bottle.
TOYOTA T-IV ? TOYOTA ATF WS ? May i to replace? | ATF, Differential, Trans, Brakes, P/S | Bob Is The Oil Guy
"Toyota does clearly indicate that THEIR own ATF-WS is NOT compatible with T-IV or Dexron ATF and they recommend only the WS be used in vehicles that call for it. It makes perfect sense that they are not compatible because the additive chemistry is different. This is the same reason you should never add "magic" additives to ATF's to convert one to meet another spec - leave the chemistry work to the reputable ATF manufacturers since they spend enormous amounts of money in engineering and testing of their products."
Sent from my ASUS_X00DDA using Tapatalk
- Aug 2017
- 232
November 18th, 2017 07:50 AM #305Mechanic used this:
https://cdn.pbrd.co/images/GU7WTZr.png
Dexron 3 is a type. As for t-iv, use toyota's it cost me 460/L but i think prices differ depending on the toyota branch? I just read it in some comments here in tsikot. Best to compare [but pls check your manual, not sure if t-iv is recommended]
Yes, kasama flushing. Until malinis na
Sent from my EVA-L19 using Tsikot Forums mobile app
- Jun 2005
- 3,774
November 18th, 2017 09:49 AM #306Mahal ah. 1200 lang 1 gallon ng ATF T-IV sa toyota makati
- Jul 2012
- 31
November 18th, 2017 09:52 AM #307
- Aug 2017
- 232
November 18th, 2017 11:26 AM #308
November 18th, 2017 01:38 PM #309
use dex3... toyota typeiv is for newer transmissions.
- Jun 2005
- 3,774
November 20th, 2017 10:35 PM #310
Daming issue ng SU7:grin:
Xiaomi E-Car
