Had mine done at Fronte in Banawe for our Starex, dialysis process also, it now pulls good as new. Van was hesitant to pull after upshifting before.
nag-inquire ako sa mitsubishi casa... gumagawa daw sila ng dialysis process pero 6 liters lang daw ang kailangan na ATF. total cost would be P5400. is that really a complete dialysis? sabi naman nila yes daw kasi they will also drain the torque converter.
nagtataka lang ako kung bakit 6 liters lang eh parang nasa 10 liters ang nakalagay sa manual...![]()
i wonder kung gumagawa nito sa customer's cradle or servitek las pinas (just before alabang)
anyway, medyo maselan ang mga honda sa atf so kailangan ba lahat ng atf ipasok habang dialysis iyong oem atf? ours kasi is a civic fd 2.0 s-l so i suppose medyo madami-dami ang atf na kailangan ko nito
That's expensive. Did they show you their dialysis machine?
The number of litres used for the process depend also on the extent of the dirtiness of your existing ATF. Years ago, i used 20 litres on a used Corona we bought (the total bill was P 5,000+ at Autotechnika when it was still open).
I just change the ATF of my Hi-ace everytime I change the engine oil. It always have the shiny and clear color. No problems with the AT so far. I'm planning to dismantle the pan underneath but it seems to be a tedious job. So I guess regular short time interval of ATF change is better and more practical than this dialysis method.
For hi mileage cars with 1st time to replace ATF, you can have this same or better results than dialysis..
1. Drain AT fluid
2. Remove the pan, replace AT strainer and gasket.
3. Re-fill
4. Use the car for 1k. (This will allow fluid to dissolve some more sludge)
5. Drain and re-fill again.
actually sir sa phone lang ako nag inquire about their dialysis process... yung color ng ATF ko is currently light brown sa paper towel pero wala namang burned smell. kaya gusto ko na din palitan lahat ng fluid.
sa servitek marcos hi way may dialysis daw sila pero i haven't seen kung meron talaga silang transtech...
Imho servitek (mostly) may teanstech machine na. Sa cavite aling aguinaldo hiway meron na eh.
Sent from my GT-I9300 using Tapatalk 4 Beta
sige thanks sir... will try and visit servitek sa aguinaldo. sa dasma yun diba?
Imus pa un sir, near imus medical center
sige sir bisitahin ko na lang sila... magdadala lang ako ng sarili kong ATF. thanks!
Question about the dialysis style. Do we need to use the actual fluid during the "clean and drain" process? I just called one of the shop on the banawe and as per sales guy, they have regular fluid (much cheaper) for cleaning and you will use only the actual fluid for final process. Is this true? Or should we use the actual fluid for the whole process of dialysis? Thanks!
In my case we used the actual fluid but this was just regular ATF. I guess if your ATF is really dirty and you plan to put a designer fluid, it should be okay to flush first using a cheaper ATF then you start cycling with the more expensive one as the system clears up.
