complete atf flushing? shops with ATF transfer machine will be the best place you should go but if you are on a tight budget, you can DIY also...
all you need is a good helper, a funnel and your guts to do it....
DIY drain and replace ATF, spares the fluid that is in the torque converter. That's what makes dialysis process way better. Also, they include cleaning additives in the fluid for some other fluid that might not still come out. Cleaning it as well in the process.
