^ sir hindi pa ako nagpapapalit... pero sabi sa manual 9.7 liters.
Question about the dialysis style. Do we need to use the actual fluid during the "clean and drain" process? I just called one of the shop on the banawe and as per sales guy, they have regular fluid (much cheaper) for cleaning and you will use only the actual fluid for final process. Is this true? Or should we use the actual fluid for the whole process of dialysis? Thanks!
laking bagay ng drop pan cleaning - had mine done sa may Shell sa Araneta Avenue. had my dialysis done but only helped quite a bit, hirap pa din sa cold start and halos 3000rpm kada upshift. noong kinalas yung pan and change filter, saw very small shavings, and yung pan que horror parang malapot na chocolate icing.. as in sobrang lapot. nung nilinis, they had to change fluid din into dexron 3 shell spirax (di na siguro napalitan yung nasa torque converter), laki ng improvement sa cold start plus shifting halos walang pitik.
revo SR 99 on aisin 3 speed + od tranny
dialysis sir is for maintenance of the AT tranny...
pag napabayaan na ang tranny at nag chocolate na ang atf at kumapit na sa atf screen sa pan ang dumi, dapat talaga baklas na.
hindi makukuha ng dialysis talaga yun...
kung napapalitan ang atf ng regular at 40-60k at normal driving habits, hindi mag varnish at putik,
600 yung labor sir tapos atf 340 per liter. Last 40k pms sa casa nag palit ng ATF na drop pan method pero di na drain lahat ng ng nasa torque converter. Now naging 70k na nagpa dialysis na muna ako.
Ser may nabibilhan ba ng castrol mv transmax sa malapit exalta? Ganda web reviews pala dito. How is your santa fe by the way
Sa mga SM sir na may Ace hardware meron yan i think SM Sta Mesa?. BTW may upcoming sale sa SM kasama ace hardware 10% off yung mga all items between 10am and 12pm. Estimate ko mga nakaka 500kms na ko, so far so good.
Dati may "thud" sound pag nag downshift from 5th gear to 4th gear ngayon nawala na. 1st time to own a automatic kaya di ko alam tawag pero before parang sliding clutch yung feeling nung lumang ATF. Mabagal yung pickup ng power before pero now malakas na yung hatak.
Also gamit ko din to sa Montero 4x2 pero partial change lang na 4 quarts. No issues din. 340 lang per liter dapat sir yung sa GTS Congressional 450 per liter benta nila.
good day,
paano malalaman yun ATF type ng honda civic and ilan litres kelangan for dialysis? sorry, tried backreading, hindi ko mahanap yun sagot. thanks!
^^^nakasulat sa manual mo.
Kung ilan liters sa dialysis, depende sa dumi ng atf mo. Pero imho, kaya ng mga 12 to 15 liters.
Posted via Tsikot Mobile App
Good evening, can't find ATF for my Grand Starex.
Manual says Apolloil Red-1 ATF - wala akong mahanapan dito.
Ayoko kasi magpa dialysis sa casa, pwede ba dexron VI na ATF sa akin? Sabi ngkilala ko sa casa daw kasi Dexron IV daw equivalent ng ATF.
tried this last week. sobrang dumi ng atf ko used 8L to flush it our then 4L to refill. mas maganda ngaun shifting at medyo tumipid sa diesel sonsumption.
had this done yesterday on our suv. used up 13 liters all in all in the process. next time dapat siguro mga 15-16 liters para completely sterile na uli iyong loob ng tranny![]()
Ilan liters naman po ang magagamit if hindi mag pa dialysis? Montero 4x2 non vgt at.
Sent from my iPod touch using Tapatalk
