Page 17 of 22 FirstFirst ... 7131415161718192021 ... LastLast
Results 321 to 340 of 440
    Jan 2012
    #321
    Quote Originally Posted by misterioman View Post
    For AT troubles, maayos kausap to si Macmac. Dating tao ni Leonard Bulaong. Humiwalay na. Mejo magulo kausap si Bulaong e. and laging puno ung lugar nia sa Cardiz.
    Either maraming customer o madami di naayos.
    09198770031 -MacMac of Banawe.
    Ang negative, wala siyang sariling shop.
    Pwedeng home service. Bili ka na lang ng parts kay Fullness.
    Sent from my SM-J700F using Tsikot Forums mobile app
    maayos nga kausap at gumawa si macmac. yung mga kasama niya marunong rin; galing yata sila lahat kay bulaong, tapos humiwalay na.
    puwede rin silang home service, lalo na kung hindi na umaandar yung auto. pero dinayo ko na sila kasi malapit lang sila sa banawe. at least madali lang maghanap ng piyesa.
    ang pinagawa ko pala, transmission overhaul lang nung una, pero nung binaklas na, pati pang-ilalim pinatira ko na.
    auto ko 2003 nissan exalta grandeur gs
    Feb 2017
    #322
    Quote Originally Posted by sergeant pepper View Post
    mga master, problema ko rin po crosswind XTO mdl '02 ko. nawala ang reverse pero sa D ok naman. malakas pa umahon sa bundok. updated po ba cp number ni MacMac ng Banawe? HELP po pls.
    Mar 2017
    #323
    ano na po number ni macmac? may problem din ako sa transmission ng avanza 2007. havent use it for a year.. nabili ko second hand
    Mar 2017
    #324
    Ito number nila macmac: +63 919 877 0031
    I should say magaling nga sila gumawa kakapunta ko lang dun and ayos na ayos na reverse and shifting problems ng civic ko.. kudos to you guys :D
    Quote Originally Posted by ishrav27 View Post
    Apr 2017
    #325
    Quote Originally Posted by poltorresjr View Post
    I contacted mac mac last holy week and mukhang ayos naman sya kausap at he offered me n ndi ako kagbabayad if ndi umayos ipapagawa ko.
    Apr 2017
    #326
    Quote Originally Posted by Dekiboy View Post
    I'm having problem with my speedometer, its not stable (up&down pointer) at shifting to high gears are delayed and medjo hirap umrangkada esp s paahon.. pls help...
    Oct 2005
    #327
    i have a mitsubishi lancer 2005 cvt. i cannot shift to reverse and park. ok naman ang takbo kapag nasa drive. ano po kaya ang problema. anybody experienced this? saan po kaya pwedeng iparepair sa batangas area? currently only 120km. salamat po in advance.
    when was the last time you had your cvt fluid changed?
    Oct 2005
    #329
    just changed the cvt fluid last year. sa mismong mitsubishi casa.symptom is ayaw talaga pumasok ng shifter sa reverse and park.
    I wonder if they used the right cvt fluid. im not sure if the current cvt fluid for the mirage/g4 is backwards compatible with the old 1st gen cvts...
    Oct 2005
    #331
    thanks for the reply. how will i know po kung tamang cvt fluid ang inilagay nila. Normally when you send your car for servicing in casa, you just put your car in the workshop and you just wait at the lounge. Is there a way to check po ba? and in case maling cvt fluid ang inilagay nila, may liability po kaya ang kasa?
    ano naka lagay sa invoice or receipt?
    Oct 2005
    #333
    i will look for the receipt and check. can changing to a recomended cvt fluid fix this? or sira nasira na talaga ang tranny ko?
    old tranny bro. almost 20yo. it could be solenoid or actuators or tcm or maybe just the fluid..
    or baka need cleaning ng sensors...
    Oct 2005
    #335
    sir aside sa mga mentioned mechanic sa thread na ito, meron ka pang recomended. 2005 model yung lancer ko, 20 year old po ba ang tranny nito? salamat uli.
    2005 pala akala ko older.
    just curious, every 2-3yrs ka nag palit ng cvt fluid?
    ala ako alam for your vehicle. try fb search bro.
    Oct 2005
    #337
    every 50K km sir. so bale every 5 years yung previous 2 cvt fluid change. hindi kasi masyadong gamit yung car ko. kaya 10k lang per year ang takbo.
    5yrs is toooo long. even if the tranny is sealed, the cvt oil degrades over time.
    most unopened oils have a shelf life of 5years. paano pa pag nasa transmission na..
    Oct 2005
    #339
    update on my automatic transmission problem. out of desperation, i sent my car to mitsubishi casa. turns out it was only a broken shift knob. not so serious. however they are asking me for 8500 for the replacement. so i declined. hanap na lang sa surplus, hehehe. paid only 500 for the check up.
    kudos to mitsubishi lipa for a good diagnostic. luckily, did not sent it to fly by night mekaniko. baka binaklas na ang ang transmission ko. for the meantime tis muna sa ganito. at least usable pa.
    sensors fail.. good thing they caught it. good choice on skipping that 9k
Automatic Transmission Specialist
