Page 21 of 22 FirstFirst ... 11171819202122 LastLast
Results 401 to 420 of 440
    Jan 2011
    #401
    ano po kaya problema ng sasakyan ko. ayaw mag shift ang d. pag nasa D, laging 1st gear lang. pag ilagay ko sa 2, shift sa 2nd gear. gana naman lahat. yon lang, ayaw mag shift.
    Sent from my SM-G610Y using Tapatalk
    Nov 2018
    #402
    Sir need some advise.may car is suzuki wagon r wide,we already change the rebuilding kit of my automatic transmission,and it doesnt work.what do you think is the problem sir?
    if the fluids and solenoids and filters are ok, then its time for rebuilding the clutch pack...
    Jan 2019
    #404
    Ask ko lang po kung ano po usually ang price ng automatic transmission overhaul.
    I brought my chevy cruze 2012 sa Banawe kahapon. 75K PHP daw yung overhaul, with 5 month warranty.
    I asked about using surplus tranny, 150K naman daw.
    Ganito po talaga ang pricing ng transmission overhaul?
    Jul 2017
    #405
    Quote Originally Posted by misterioman View Post
    For AT troubles, maayos kausap to si Macmac. Dating tao ni Leonard Bulaong. Humiwalay na. Mejo magulo kausap si Bulaong e. and laging puno ung lugar nia sa Cardiz.
    Either maraming customer o madami di naayos.
    09198770031 -MacMac of Banawe.
    Ang negative, wala siyang sariling shop.
    Pwedeng home service. Bili ka na lang ng parts kay Fullness.
    Paps naggagawa paba ng transmission si Macmac? Updated paba itong number nya? May leak kasi yung transmission ng Camry 2003 ko. Ipapaayos ko sana sa kanya since maganda ang feedback sa kanya dito sa Tsikot. Salamat
    #406
    How about for City cvt specialists? May ma recommend kaya?
    Sent from my mobile using Tapatalk
    #407
    Quote Originally Posted by wowiesy View Post
    Honda will be your best bet on that, sir. Let's hope it's not belt failure. CVT fixes are mostly assembly swaps, not rebuilds.
    Aug 2019
    #408
    Newbie here, need advice po. bought a 1997 honda civic barely 2 month ago. Ok naman andar until di na nagana yun speedometer nya. I went to banawe to buy a replacement speed sensor for a 97 civic only to find out na un transmission di compatible sa speedsensor na nabili ko. So ginawa ko took the existing speedsensor to banawe and found out na pan ESI na speedsensor un nakakabit. So ibig sabihin napalitan na ang automatic transmission ng kotse. My dilema is i took it to rapide to have an ATF flush done at nakita na may leak ang mga seals sa ilalim. At present kasi kapag nakahinto ang kotse nakakaramdam din ako ng vibration sa kotse and minsan parang di agad respond ang gas pag tinatapakan.. which brings me to why i wrote here po... iniisip ko kasi na papalitan na ang transmission at ibalik sa 97 na civic uli.. tama po ba na gawin ko un o stick na ako sa existing na transmission at hayaan na palitan ang seals. Problem ko kasi if binuksan ang transmission at may iba pa makita na problema since it is a 20 yr okd transmission na din. Would it cost more to replace it o paayos na lang ng existing na transmission?
    #409
    Quote Originally Posted by Nyaminya View Post
    a lot will probably depend on your budget.
    personally, i prefer stock original.
    but you raise a valid point when buying a used car.
    "i should crawl under and see if things are stock..."
    Aug 2017
    #410
    If money is not a problem, have the tranny replaced withe the original/stock one.
    If it is not broken, why fix it? Leaks and vibration on 20yr old car is common. If the leak does not "pool" in your garage overnight, why bother? Unless you want to restore the car.
    Leak lang pala eh seal lang papalitan diyan then pa flush mo tapos OEM ATF palagay mo baka hinde OEM kinatha diyan kaya meron vibration or pwede din yun support sira na.
    Aug 2019
    #412
    Quote Originally Posted by SidCoronel View Post
    How much does a surplus automatic transmission for honda civic 1997 cost now? How much to rebuild an automatic transmission?
    Jun 2005
    #413
    You would probably better off getting surplus tranny and ask for warranty.
    Wala naman talaga magaling mag overhaul ng automatic tranny. Hit or miss yan... Madalas miss.
    May facebook post dati si ezworks garage. Nagpaoverhaul sya ng automatic tranny. Nagsunog lang sya ng pera di naman umayos. Madami pa ibang sinisi yung gumagawa pero puro excuses lang naman
    Sent from my MI MAX 2 using Tapatalk
    Aug 2017
    #414
    Sorry, I have no idea. I have not changed a Honda tranny nor rebuild one.
    Aug 2017
    #415
    Quote Originally Posted by sirkosero View Post
    Agreed, agreed, agreed.
    My tranny surplus (Sentra) was given 6mos warranty.
    Aug 2019
    #416
    Thank you for your responses... so i guess next move is to canvass how much it will cost a surplus automatic tranny plus labor...
    I don't understand, bakit papalitan nanaman if it's working? Why not flush the ATF first and then use OEM honda ATF afterwards, see if the issues will go away.
    #418
    kasi daw, it belongs to the older model esi, even as it works naman.
    Jan 2008
    #419
    Kung pang esi na transmission nyan baka pati yung computer eh pang esi na din.. kaya need mo yung pang 97 na civic.. baka kaya nanginginig yan eh kasi dapat mag taas ng konti ng rpm yung engine pang lagay mo sa drive
    Aug 2019
    #420
    I see so its not just a simple change the automatic transmission issue... problem is the person i bought the car from does not know na iba na transmission ng kotse.. although he claims to always bring the car for change oils and atf flushing yearly since its his wifes car...
    So isa din pala yan na need ko malaman if compatible un computer... so many things to find out...
Automatic Transmission Specialist
