ano po kaya problema ng sasakyan ko. ayaw mag shift ang d. pag nasa D, laging 1st gear lang. pag ilagay ko sa 2, shift sa 2nd gear. gana naman lahat. yon lang, ayaw mag shift.
Sent from my SM-G610Y using Tapatalk
Sir need some advise.may car is suzuki wagon r wide,we already change the rebuilding kit of my automatic transmission,and it doesnt work.what do you think is the problem sir?
if the fluids and solenoids and filters are ok, then its time for rebuilding the clutch pack...
Ask ko lang po kung ano po usually ang price ng automatic transmission overhaul.
I brought my chevy cruze 2012 sa Banawe kahapon. 75K PHP daw yung overhaul, with 5 month warranty.
I asked about using surplus tranny, 150K naman daw.
Ganito po talaga ang pricing ng transmission overhaul?
How about for City cvt specialists? May ma recommend kaya?
Sent from my mobile using Tapatalk
Newbie here, need advice po. bought a 1997 honda civic barely 2 month ago. Ok naman andar until di na nagana yun speedometer nya. I went to banawe to buy a replacement speed sensor for a 97 civic only to find out na un transmission di compatible sa speedsensor na nabili ko. So ginawa ko took the existing speedsensor to banawe and found out na pan ESI na speedsensor un nakakabit. So ibig sabihin napalitan na ang automatic transmission ng kotse. My dilema is i took it to rapide to have an ATF flush done at nakita na may leak ang mga seals sa ilalim. At present kasi kapag nakahinto ang kotse nakakaramdam din ako ng vibration sa kotse and minsan parang di agad respond ang gas pag tinatapakan.. which brings me to why i wrote here po... iniisip ko kasi na papalitan na ang transmission at ibalik sa 97 na civic uli.. tama po ba na gawin ko un o stick na ako sa existing na transmission at hayaan na palitan ang seals. Problem ko kasi if binuksan ang transmission at may iba pa makita na problema since it is a 20 yr okd transmission na din. Would it cost more to replace it o paayos na lang ng existing na transmission?
Leak lang pala eh seal lang papalitan diyan then pa flush mo tapos OEM ATF palagay mo baka hinde OEM kinatha diyan kaya meron vibration or pwede din yun support sira na.
You would probably better off getting surplus tranny and ask for warranty.
Wala naman talaga magaling mag overhaul ng automatic tranny. Hit or miss yan... Madalas miss.
May facebook post dati si ezworks garage. Nagpaoverhaul sya ng automatic tranny. Nagsunog lang sya ng pera di naman umayos. Madami pa ibang sinisi yung gumagawa pero puro excuses lang naman
Sent from my MI MAX 2 using Tapatalk
I don't understand, bakit papalitan nanaman if it's working? Why not flush the ATF first and then use OEM honda ATF afterwards, see if the issues will go away.
I see so its not just a simple change the automatic transmission issue... problem is the person i bought the car from does not know na iba na transmission ng kotse.. although he claims to always bring the car for change oils and atf flushing yearly since its his wifes car...
So isa din pala yan na need ko malaman if compatible un computer... so many things to find out...
