Page 20 of 22 FirstFirst ... 1016171819202122 LastLast
Results 381 to 400 of 440
    Aug 2017
    #381
    Mga Sirs,
    Hope you can help me.
    I have a 2010 Chevrolet Captiva A/T 2.4 gasoline engine.
    Nagkaproblem sya and ayaw tumakbo now. Noong una pag D mode tumatakbo pero kapag malayo layo ayaw na. Sa manual mode gumagana sya sa 1 and 2. Kaya nadala ko pa sa casa nun..sbe transmission valve assembly daw..pero bukod sa mahal wala silang parts available. mga two weeks after, hindi na din tumatakbo kahit sa 1 or 2...pero reverse walang problem nagrereverse sya...
    nagtry ako sa chevrolet mechanic sabi nya computer box daw... sbe sa thunder 38k daw un bnew nun...so i tried having it repaired sa RAMSA eh ok naman daw yong computer box...sbe naman fuse pero wala namang problem ang fuses...may nagsasabing wiring pero di naman sure...
    I'm not sure kung ano sira nito...sana matulungan nio ako...
    Many thanks in advance!
    napalitan na atf?
    Dec 2017
    #383
    sir does leonard fix at of crosswind it wont engaged
    Jun 2004
    #384
    Quote Originally Posted by Pinoy AKo View Post
    Mga Sirs,
    Could be worn seals, kulang sa pressure kaya nde nag engage yung gears. Kung tingin mo sure naman diagnosis ng casa try mo hanap parts online pa ship mo na lang. Ask mo sa casa yung part #.
    Dec 2017
    #385
    sirs
    need help
    ayaw ng magengaged ng transmission ng aking crosswind nastuck kz ng 1 year then pina detail ko ng kunin ko na ayaw n
    tumakbo magengaged sglit pg change gear k ayaw n
    #386
    Quote Originally Posted by willysantos07 View Post
    sirs
    need help
    i don't have a crosswind, but
    first thing i'd do, is look around in the car, including engine bay and even underneath, for connections that may have been loosened when the car was being detailed.
    Nov 2017
    #387
    Change mo muna a/t oil nyo sir then have your strainer cleaned as well. Baka kasi barado lang yung atf strainer and medyo namuo na ang atf mo sa tagal ng pagka tengga.
    Sent from my Redmi Note 4 using Tsikot Forums mobile app
    Dec 2017
    #388
    Mga sir/madam happy new year to everyone. I just signed in and if anyone could shed some light to my problem. I have a 20yr old car (accord 97vti s matic) got it 8months ago recently. I have been having problems in delay of shifting gears P to D, P to R. Pero ang pinaka matagal sa kanya ngayon is yung reverse, Sometimes forever before it engages. Shifting from 1st to 2nd needs to climb up to 3krpms the rest of the gears shifts normal after going through 2nd gear. Changed the atf recently with honda atf 3x already. I did some reading and ran through with solenoids. Maapektuhan po ba nia ung shifting ko with faulty shift solenoids. The car was shifting perfect nung nakuha ko sya. Other than that everything is perfect. Thank for reading my post and for any response.
    Sent from my SM-N900S using Tsikot Forums mobile app
    Nov 2017
    #389
    Have your car checked muna by an a/t specialist sir. If solenoid sa transmission ang issue,you better change the entire tranny na sir. Sa akin dati, ang analysis ng computer eh solenoid din pero ni try muna namin palitan ang ecu ng transmission, ayun ok na ang shifting.
    Dec 2017
    #390
    Quote Originally Posted by reddik2017 View Post
    So as what you said if solenoid ang problem palit tranny na sir? Thanks sa feedback much appreciated. Wala bang option yan sir change the entire tranny talaga.
    accord vti s 97
    Nov 2017
    #391
    Quote Originally Posted by Genziss View Post
    accord vti s 97
    Sa pagka explain kasi sa akin, wala namang magbebenta ng solenoid (lalo na mga surplus shops) lang sir kasi yan ang buhay ng automatic transmission. I don't know kung makakabili ka niyan sa casa, but if ever baka mas makakatipid ka if bumili ka ng surplus automatic tranny sir.
    Pero have it scanned muna sir at baka mamya mga sensor lang pala ang problema. Sa labas ng casa, around 1.2-1.5k singilan pag nagpa scan niyan sir.
    Dec 2017
    #392
    Thank you so much sir. Kahit mag nnew year na may replies pa din. Solid. Thanks and happy new year to you and to tsikot fam.
    accord vti s 97
    Jan 2018
    #393
    Sir, how was your repair at Baltak? Thanks.
    Jan 2018
    #394
    Quote Originally Posted by charles_darwin View Post
    Thank you, Sir OJ for the quick reply.
    I haven't heard of anyone who has the proper computer to diagnose the car's problem. Can you suggest me a place near Banawe QC where I could bring it for diagnostics?
    Thanks again.
    Jan 2018
    #395
    A/Ts have solenoids (electromechanical device) in them that control fluid flow to engage certain gears or clutch packs. Needless to say, if there's a problem with the powertrain control module (PCM-the computer that controls the A/T), or if the solenoid(s) themselves are defective (ie. stuck, clogged, open/shorted, etc.), the A/T will not be able to cycle through all the gears at best, or not propel the car at worst.
    About the warning lights, don't ignore them and just discount them as instrumentation problem. Have it checked immediately using a diagnostic computer to tell you or the mechanic exactly what's wrong with your car.
    Sir, OJ88.
    Can I contact you? er_quisumbing*yahoo.com
    Feb 2018
    #396
    Sir saan ba nakakabili ng automatic transmission for Ford Everest model 2008 4x4 at do you have an idea kung magkano? Kailangan ko kasi ng comparison dahil may nag quote sa akin na shop ng 55 thousand for overhaul and repair. Kung surplus naman daw ipapalit nila around 90 thousand including labor.
    Kindly advice me. Yong kasing sasakyan ko habang nag-travel kami sa Tanay, Rizal parang may pumutok na hose akala ko yong aircon pero hindi pala. Huminto yong sasakyan at ayaw na mag move pero umaandar yong makina.
    Salamat po.
    Feb 2018
    #397
    Quote Originally Posted by Fulcrum View Post
    im looking for an automatic transmission specialist in the area of Quezon City, any recommendation?
    thanks
    Nabasa ko dito, puro kay Bulaong sa Banawe, maganda ang feedback ng mga taga-tsikot member
    Aug 2004
    #398
    Quote Originally Posted by Agjc View Post
    Di maganda ang experience ko kay Bulaong. Umayos naman ang AT ko pero naka-ilang backjob din dahil sa pumuputok na axle seal. Yung major leak sa Greenbelt nangyari naglawa ang pulang ATF sa parking slot. Buti na lang bukas pa Blade nakabili pa ako ng ATF para ma topup.
    Make sure lang na bantayan mo ang trabaho nila pero prepare to spend the whole day in their shop. My bad experience happened a long time ago though (7+ years) so sana umayos na ang trabaho nila.
    Mar 2018
    #399
    Thank you all, guys!
    Mar 2016
    #400
    Quote Originally Posted by b16sir_stock View Post
    our mechanic have fixed our CRV AT and he works home service kaya makita mo talaga how he does it.. pm na lang for me if need he's contact information...
    B16 sir, can you possibly text me your mechanics number who fixed ur CRV so I can also avail of his service. Thanks
Automatic Transmission Specialist
