Page 19 of 22 FirstFirst ... 91516171819202122 LastLast
Results 361 to 380 of 440
    Jun 2017
    #361
    Quote Originally Posted by basti08 View Post
    Spare the users here of the hassle and divulge the name of the shop. baka bukas lang magawa sa iba yung nagawa sayo. CVT is for 2003-2008 City and Jazz. and current models City, Jazz and Civic. old LXi should use just ATF, not CVTF, sinira na nga nila oto, wag ka mag bayad. insist that be repaired FOR FREE!
    Hello mga paps. i just got back from the shop. The bargain i got was i got to pay for the 12ltrs ATF and the labor for free. They used a transmission fluid changer machine. The name of the shop is Real LubeMan in Tiongko Ave. Davao City. Thank you so much for all your inputs. It was really a big help.
    #362
    Quote Originally Posted by seven_ian View Post
    dabaw pala...
    hindi ku nga pupuntajan yan.
    Jun 2017
    #363
    Hello mga paps. may question po ulit ako. Paano ba ifix yung issue na kung matagal nka park yung car, lalo na sa 1st start in the morning, when i shift prom P to D4, medyo matagal ang pag engage ng D4. Matagal bago tumakbo ang kotse. Wla naman po ibang issue ang tranny liban lang dun. Kakapalit at kakaflush lang pala ng ATF but still andun pa rin yung issue. It still shifts smoothly when im already moving. Honda Civic 1996 LXi nga pala unit ko. Tnx!
    May 2017
    #364
    Guys, problem is.. yung shifter nawalan ng lock.. napakadaling galawin nung kambyo.. Honda CRV 2004 AT. Sabi ng mechanic sa Bulacan, palitan daw transmission.. 40k + 10k labor. Dinala ko sa Banawe, di nmn daw sa transmission yun.. sa shifter daw.. pero ang price kung gusto ko daw palitan ang transmission is 15k+3k labor. pero ganun pa rin daw yun.. Nag drive test kami, sabi ng mechanic, good p daw ang transmission kasi umaahon pa sa gutter kahit di tapakan yung accelerator. Mahirap daw makakuha nung shifter.. Anybody who can give me idea what to do? Dinala ko n dati ng kasa, kaso kung ano ano sinasabi, di daw nag shift sa 4th gear, ang dahilan pala (nung pinatinan ko ibang mechanic, loose contact lang daw yung solenoid), kaya di ko rin mapagtiwalaan yung casa kung ano talaga sira.
    Ang magulo, bawat mechanic iba sinasabi..
    Help po.
    Jul 2016
    #365
    Quote Originally Posted by Marlo G View Post
    Help po.
    Jspecs Banawe / Marlon - 09178284622
    #366
    This may sound stupid but please bear with me. Are you using sufficient coolant in your radiator? When was the last time you changed it?
    Jan 2010
    #367
    Quote Originally Posted by Woof View Post
    curious ako dito sir, since wala akong masyadong alam sa sasakyan. can you tell us po yung relation ng coolant sa radiator against sa transmission? innocent question po ito, di po sarcastic. gusto ko pong matuto.
    Dec 2007
    #368
    Quote Originally Posted by Janemar View Post
    Sanay din kaya sila sa Toyota Hiace surplus AT ?
    Sent from my ASUS_Z012D using Tapatalk
    #369
    Quote Originally Posted by itoangtama View Post
    Just to add in this query, it is not specifically the coolant that affects the AT, but the performance of the whole cooling system itself. Remember that the transmission (AT) sends fluid to the radiator to be cooled, if the cooling system is not efficient or frequently experience overheat, then your transmission will also overheat. This I say will damage or shorten the life of your AT.
    #370
    ^ That is correct. The inverse is also correct. Coolant (not water), together with pressure, raises the boiling temperature of the coolant/water mixture in the radiator. But coolant is also poorer at holding heat. Water by far has better heat holding ability. Running straight water will actually make your engine run cooler. But you don't want to do that because adding coolant increases boiling point, prevents freezing, and has corrosion inhibitors to protect aluminum and other engine parts (i.e. pump, gaskets, hoses). Water will straight out eat into aluminum and rust out the iron in the engine.
    During early morning startup, the coolant mixture actually helps the car warm up faster and helps get the ATF flowing to its operating temperature around the cavities, passages and solenoids of the AT housing. Shifting immediately before the ATF is warm can usually lead to shift delay, shift shock and/or harsh shifting, particularly with older vehicles.
    Jan 2010
    #371
    thank you mga sir!
    Jul 2017
    #372
    Makiki ride lang po dito since I am encountering the same issue. Tuwing umaga hirap mag shift sa second gear ang car ko, rev is reaching 3.1 to 3.3 before sya mag switch ng gear but after this, ok naman na. Also, tuwing umaga, matagal din bago mag engage yung reverse gear. Ano po ba magandang gawin dito, my car is a Honda Civic 96 VTi model.
    Thanks in advance...
    Jun 2005
    #373
    ^ replace atf muna
    May 2017
    #374
    Nid to replace the repair kit of the tranny sir. Ganyan din ung sakin. Had it replace at makunat n kc.. After that, wala n problem...
    Sent from my C6833 using Tsikot Forums mobile app
    Jul 2017
    #375
    Quote Originally Posted by Redstep View Post
    Thanks Redstep. San nakaka bili ng tranny repair kit sir? mga magkano kaya ito? also, may alam kabang shop na magaling at trusted na gumagawa neto? Q.C. area ako sir.
    *sirkosero, Thanks sa advise. Nag palit na ako ng ATF pero ganun parin.
    May 2017
    #376
    Im from muntinlupa sir. And ung mechanic ko dito ang bumili. Un lang sir ang papalitan dyan. We have the same problem. Un lang ang pinalitan ko sir....
    May 2017
    #377
    Gaskets lang un sir... Then i change my atf and thats it.
    Jul 2017
    #378
    *Redstep - Sir maraming salamat sa suggestion and clarifications.
    *Tsikot members - Pa recommend naman po ng shop Q.C. or Banawe kung san maganda bumili nitong Tranny Kit. Pa recommend narin ng shop na trusted and magaling gumawa.
    Maraming Salamat po in advance...
    #379
    ^ backread ka bro. naalala ko madaming nabanggit na dito sa thread na ito na tranny specialists dyan sa qc area. pagtyagaan mo na lang sa pagbabasa
    Jul 2017
    #380
    Mga sirs I need your help/advise!
    Recently, yung Honda Jazz ('05) AT ko is having a rattle when in low gears plus may noise sya when in gear and accelerating. So I decided to bring it on my company's accredited repair shop. First recommendation nila is to replace the Flywheel. I proceeded kasi dati pang recommendation ng Honda yun kaso lumalabas lang sya dati when I'm in reverse.
    After nilang mapalitan, naobserve ko na wala na yung rattle, however nandun parin yung noise. They have checked the wheel bearing pero nakita nila na in good condition pa, so they have assumed na sa transmission na ang problem. Unfortunately hindi nila kaya mag overhaul ng transmission so I need to find a new shop na mura and reliable.
    Note: Wala akong napapansin na changes sa performance except for that noise when I'm driving. Nakaka worry lang kasi maingay sya...
    I hope you can help me sirs
Automatic Transmission Specialist
