Hello po... magandang gabi po..ask lng po pag saang shop po nagaayus ng honda fit? Problema ko po kc pag pa accelerate n sasakyan between 0-40 may nagvivibrate sa part ng makina.and ung brake at abs nakailaw po.. pinacheck ko po kc sa casa.. ung gitnang engine support iba daw po sa local? Any reccomendation kung saan shop ko po pwede ipatingin? Salamat po..
Any updates? Is Baltak and bulaong bros pa din ba highly recommended sa metro?
How about making current list of recommended auto tranny specialists, top five?
I just had my tranny fixed by alex bulaong. Yung issue nya is delayed shifting, mag high gear lang sya pag umabot na ng 3k up yung rpm. I scouted alex bulaong sa internet and decided to try him instead of my previous plan na mag pa dialysis muna. I was happy with the result kasi naayos nya yung problema ng tranny ko, although it took two days to fix pero mas na impress ako sa nangyari. I came back kala ko may problema yung gawa nya kasi hirap lumampas ng 60kph yung takbo pag naka buwelo, but he found out na stock up yung calipers ko and had it fixed himself. Impressed ako kasi he knows really from experience kung ano itrou-troubleshoot. I thought gagastos pa ako sa tranmission repair nung pagbalik ko, pero mas naayos pa yung kotse ko sa nangyari. Maayos naman sya kausap and will find ways na maayos yung problema the right way. damage was 2.5k for the tranny work and 800 petot sa brake cleaning. 3 mos warranty so we'll see if this is pansamantagal.![]()
Hi mga boss san kaya magaling umayos ng CVT honda fit galing japan? nag bblink na kasi "D" niya minsan at hindi na smooth idrive parang delay shifting pa. kailangan ko lang gamitin sa school hanggang 2015 lang sananamomroblema na ako huhu hanggang 160k mileage lang sana ok na para lang sa school. May ma rerecommend ba kayo mga sir na shop dito sa metro manila? south area sana po
thanks
Are you the first owner ng vehicle?? Have you checked also the fluid level and kung CVT fluid talaga yung nakalagay ^_^
any one here experience using PEAK brand ATF, dextron III i have plan to use this brand for my daughter car Honda civic 1999, and how many li for this old car, thanks to all tsikoters
guys I need your suggestion. kakapalit ko lang atf pero medyo parang hirap pa din magpalit ng gear. un regular atf change kang pinagawa ko. nun na drain yun luma medyo nasa darker side yun lumabas..sayang hindi ko nabasa yun about sa atf dialysis bago ako nagpapalit.
sa tingin nyo ano mas maganda gawin, dalhin ko kay mel casaba or pa atf dialysis ko na lang muna?
yun kotse ko honda city matic 1998. hindi ko alam kelan huli napalitan un atf iniwan lang kase ng tiyahin ko sken itong oto nya pero based sa nakita ko mukhang matagal na hindi napalitan. ayos naman yun D/R nagana naman..ramdam ko lang na medyo hirap sya mag change gear. ano kaya maganda atf bilhin ko? wala na user manual yun oto eh hindi ko alam ano recommended.
mas maganda ba dialysis muna o pa check ko muna kay mel? pag ganito ba yun tranny possible na pa overhaul na? TIA
Kamakailan hindi agad nag-engage ang transmission ko kapag nilalagay sa reverse. Minsan kailangan pa i-rev o kaya balik neutral muna tapos reverse ulit. Saan ba maganda magpatingin ng tranmission near Madrigal Business Park, Muntinlupa? Honda Civic 200 LXI.
sir, yung isuzu trooper ko po na automatic trans pag inapakan mo talaga yung gas pedal tumataas lang yung rpm pero ganun parin yung takbo. transmission na kaya sira nito?
Posted via Tsikot Mobile App
Jhunter, okay naman ang atf level mo no? Hirap nyan pag pedal play need mo pacheck asap bago byahe long distance
Help po..newbie here..mine is a toyota corolla gli 95..dati pag tumatakbo ako ng above 80kph nagshishift ung auto then bumababa ng 2000rpm lamang para sa cruising speed pero recently napansin ko na di na siya nagshishift at ung rpm eh umaabot na ng 3000rpm.pag inapakan ko pa ang gas bumibilis naman ung kotse pero umaabot na ng 4000rpm..ano kaya problema po?nagpapalit na ako ng atf at linis filter pero ganun pa din..everything seems to work fine..smooth shifting sa ibang gear..wala din problema sa D sa R at sa 1 or 2 at P...
Hello sir meco.....nagkataon exacto ang issue natin right now (starex 2001) ...kailangan umabot ng 80+ pa bago mag OD (overdrive)!....parang hirap na hirap ang makina.....iniisip ko kasi dapat mga 60-70 lang dapat mag OD na diba?............mga idols nag aalala ako kung may diperensya ba ito or what?
Thanks!!!
Napaayos ko na kotse ko *louiearboleda.. nakapagpalit ka na ng ATF??? kung oo, gaya ng sakin, ung solenoid valve ng OD ang problema..nag leleak na..pacheck mo ung sayo kung ganun din problema..pacheck mo muna lahat ng wires/connections..kasi ung ibang mga shops, transmission kaagad ang duda..ibababa agad transmission..mura lang ung papalit ng solenoid..buti di ko pinababa ung transmission dun sa isang shop na napuntahan ko..papadialysis ko din kotse ko para malinis ung system..
