Quote Originally Posted by jkwokng View Post
I have no problem sa expertise nila BULAONG. Improve lang nila workmanship. I bought surplus tranny from BULAONG last month. Iyong pinalitan kasi ang tranny ng Altis ko, hindi mahigpit pagkakabit sa pan oil seal so nag leak tapos binalik ko the next day para ayusin nila.
After one month, I decided to flush the ATF iyan kasi advise nila BULAONG . Since busy ako , I just went to Speedyfix sa SHAW blvd malapit kasi kami doon at doon ko nalaman may leak galing OIL SEAL ng transmission at sa CV joint (hindi mahigpit at magandang tie wrap ginamit kaya nag leak grasa). Inayos naman nila lahat ng nakita nila.
I used Royal Purple ATF (fully synthetic ATF). Ok itong brand na ATF, mahal lang nga pero ang laki improvement sa shifting.
I don't think you can give the credit of your improve shifting to "royal purple" . It's a must to have your ATF replaced after a week of installing a new transmission. Pag bago ang transmission na kinabit normally may mga shavings ng metal na nag circulate sa system ng transmission hence causes abnormal shifting. That's why they highly recommend that you have your ATF replaced after a week . Yung type of ATF na gagamiting naten is for the prevention of wear and tear. This is just my own opinion. When I had my ATF replaced nilagyan ni BULAONG ng magnet sa oil pan para daw dun pumunta ang metal shavings/dirt incase meron sa system. When he replaced it wala daw kaseng nakalagay na magnet sa pan kaya daw hindi maganda shifting ng sasakyan ko. Open si Bulaong sa mga backjobs. Don't hesitate to bring it back to Leonard pag may problema pa sasakyan mo.
Wrathbu
