Page 5 of 5 FirstFirst 12345
Results 81 to 89 of 89
    Aug 2009
    #81
    mga sir. tanong lang meron ako civic 1.8s matic, laging blinking yung green light sa drive kahit naka parkl or kahit saan gear mo ilagay naka ilaw parin at blinking yung light katapat ng D. ano kaya ang problema? check ko atf parang kulang lang ng kaunti.
    #82
    Quote Originally Posted by zed71 View Post
    Have your car OBD II scanned sa casa or SpeedLab, yung blinking light na yan ay trouble code. Wala bang strange behavior ang transmission while driving?
    Aug 2009
    #83
    Quote Originally Posted by CivicVTi View Post
    wala naman strange behavior laka parin humatak yung nga lang lagi nagbiblink yumg green light nya
    Aug 2009
    #84
    Quote Originally Posted by atly View Post
    Mga bossing, please help. . . This is about my A/T Crosswind.
    After being idle for about 4 days, ayaw na magengage sa 4th gear or last gear crosswind ko. PArang palaging lang naka-off and OD. . .Its as if nasa 3rd gear lang ako palagi kahit mataas na RPM ko. . .hanggang 70km/h lang takbo. . .naka-off or naka-on and OD, walang pagkakaiba. . . Ano kaya ang defect ng car ko. . . would it just be electrical or transmission na. . . Bago lang palit ang ATF ko so i dont think ATF ang problem. . .
    Thanks in advance. . . .need your advice. . .
    pacheck nyo na yan sa shop sir baka sa ECU..madami ako nabasa na negative reviews about Automatic tranny of isuzu not the engine.
    Feb 2010
    #85
    paps, maybe you need to reset your ECU... hindi ko lang sure sa ibang car pero sa Toyota, you just have to remove the ECU fuse or negative terminal of the battery to reset error codes. Do this for at least 5 mins bago ikabit ulit. Pero if ayaw pa rin maalis error, meron sa Banawe na nag reset ng ECU using scanner. Try to text or call Boy 09105815076 marami nagpapagawa sa kanya na Honda na meroon error code...
    #86
    Hello po. i need your help po kasi meron po akong nissan terrano a/t imported diesel 1995 model....parang me problema po ata ang trans....ganito po yun pag naka takbo na po ang car mya mya po nararamdaman ko may vibrate and din hindi na uusad ang car pero buhay pa makina naka (D) Drive po, parang hindi kumakapit ang gear kahit apply ako ng gas pedal hindi na sya tatakbo...so ang ginawa ko patay muna na makina ng mga 30 secs. din start ulit takbo na naman mga 300 meters or minsan lagpas pa.hindi na naman kumakapit ang gear os transmission hindi na sya uusad kahit naka drive ako......pablik balik po ang syan ganyan parati...patay makina din takbo na naman.....ano po kaya possible problem? transmission na po ba? i need ur help po
    Jun 2008
    #87
    mga boss ako din may problema,
    nissan altima 1992 model, 2nd hand transmission from evangelista
    nag-slide or may jerk ang clutch ko from 1st gear to 2nd gear.
    where can you suggest ito pagawa na mura lang at maayos gumawa.
    thanks
    Nov 2006
    #88
    Quote Originally Posted by alwayz_yummy View Post
    as far as i know, wala pa ako may alam na naka-force induction na may AT...pero siguro kung low-pressure ok lang palagyan, ung 1-2 psi lang na tuned for torque para magamit mo for everyday use..pati din headers/exhaust mo tuned for torque din...para balanced ung car mo...good torque,good HP...
    about sa matic, mostly kasi pag-AT stock lang ang pinapadala, unless pa-order ka ng special tranny,e....kaya mostly wala kang pagpipilian aside sa "freshness" ng tranny...just choose the most unspoiled a/t, and ok na lahat...
    Marami na ako alam na naka force induction na AT * natakbo sa BRC including me pero dko tinatakbo, pero mas matibay pag naka manual transmission. kung mag force induction ka ng 1-2psi wag mo nalang e turbo sasakyan mo sayang lang palit kalang ng branded na air intake,crank pulley & etc makakagain kana ng Hp.
    May 2012
    #89
    mga sir may problem din ako sa automatic transmission ko, ford escape 2008 model ung akin. minsan kumakagat ung reverse nya minsan neutral and minsan naman neutral nya nag didrive.. any advise, may naka experience na dn ba ng same problem ko and baka may marerefer kyong mekaniko?! thanks
Automatic Transmission Problems [Merged]
