Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 58
    Feb 2012
    #21
    I was reading the manuals of our AT rides for the atf replacement :
    Toyota - replace only when necessary or when driving regularly in harsh conditions
    Honda - every 60kkm
    Hyundai - every 90kkm
    I guess the practice / casa schedule of replacing atf every 40kkm is because of the heavy traffic on the Metro (???)
    Quote Originally Posted by box_type View Post
    been driving my corolla ae92 (manual) for seven years without changing transmission fluid, so far wala pa naman masamang nangyayari sa transmission ko...
    Kaya pala nung nagpapalit ako ng Altis 2003 ATF last year mukhang okay pa naman. That is after more or less 8 years.
    Honda - every 60kkm
    Aug 2012
    #22
    For Toyota Innova AT, nakalagay sa owner's manual for ATF every 40,000 km or 24 months, I = Inspect and correct or replace as necessary.
    #23
    Guys paano ko ba malalaman kung ilang litro magagamit ko na ATF fluid sa kotse ko. Lancer singkit kotse ko?
    #24
    Quote Originally Posted by Mits View Post
    Read the manual. Daming downloadable manual sa internet.
    #25
    ito yung ginamit nung nagpa atf change ko-
    Aug 2005
    #26
    Ano yung sinasabi nilang filter? I have a toyota innova g 2008. I haven't changed the filter inside the a/t. Ano exactly ang tawag dun?
    Dec 2009
    #27
    Quote Originally Posted by r_delro View Post
    ATF oil pan filter... metal screen lang yun technically. to trap large particles...
    the smaller metal particles are held by the magnet inside the atf pan.
    #28
    That is correct bro.
    But I am not taking any chances and so I am having my atf replaced in a few weeks....
    And I guess the casa interprets this as replace....
    ^ meron di pala dyan "dialysis machine" sa shell j. aguilar? magkano kaya ang pa-dialysis dyan bro?
    P1000 for the service bro. Asked them an hour ago... They were recommending the use of a cheaper dexron3 atf to flush out. Cost is P280 per liter. I think I will be using the original Toyota atf for everything. BTW, asked Bicutan for a quote, they were recommending 3 liters of atf only si just drain and replace.... But total cost of pms at 40kkm is P15k.....
    Apr 2015
    #29
    Sir, aside from what is stated in the manual, is there any other way to check the condition of ATF for D4D engine. May dipstick din ba sya like sa engine oil?
    Aug 2005
    #30
    Quote Originally Posted by miko101130 View Post
    So kung metal screen lang siya. Linisin lang siya or palit din dapat. Is this a necessary replacement item?
    Aug 2012
    #31
    Linis lang. Pag damaged, doon lang need palitan.
    Jan 2009
    #32
    Quote Originally Posted by newtocar View Post
    Yup.
    Dec 2009
    #33
    matagal dumumi yung metal screen na yan kung regular ka nag atf change... meaning every 40,000kms max....
    if matagal ka magpalit atf, beyond 40,000kms, pag tinangal mo yung screen na filter na yun madaming dumi sobra.
    what you need to clean is the magnet sa loob ng atf pan, madami metal fillings na nag clump together around the magnet.
    i will advise you to use the original atf pan filter should you choose to replace it.
    a branded ATF with spec higher than what you need is also advisable, that way you are also buying a little further of margin.
    use what is spec'd and compatible.
    some are higher spec'd but are backward compatible and some aren't.
    Apr 2015
    #35
    Yup.
    Ah okay, sir pwede ba padanin jan sa lagayan ng dipstick ang pag lagay ng ATF, gamitan ng funnel?
    Aug 2012
    #36
    I just checked Mitsubishi ASX maintenance schedule. Under normal driving condition, no mention to change ATF, even up to 240,000 km. But under severe driving conditions, it says change ATF every 48,000 km or 24 months. No mention to change ATF filter, unlike for engine oil.
    more or less pareho lang din pala sa customer's cradle ang cost ng pag-gamit ng transtech machine nila
    i was told na pwede din iyong castrol equivalent ng oem atf ng mitsu kaso to play safe i stuck it out w/ the oem atf na lang din. iyon nga lang, it did cost me a pretty penny ika nga
    Jun 2009
    #38
    Accdg to this, i should change my atf in my ranger every 250,000kms. My SA says every 80,000 kms though. Kanino ba ko maniniwala? Lol imageuploadedbytsikot-forums1443328729.460347.jpg
    #39
    Quote Originally Posted by dcph172 View Post
    Mas maniwala ka sa documents or manuals kaysa sa mga SA.
    Aug 2012
    #40
    Wag maniwala sa SA. Best to inspect the ATF first. For Ford Ranger, change ATF at:
    Normal driving conditions: 240,000 km
    Extensive idling and driving at low speeds: 170,000 km
    Towing: 100,000 km
    Operating on dusty conditions: 48,000 km
    Off road conditions: 48,000 km
ATF change
