1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Hi guys, i just bought a vios 1.3MT dual vvti.
Ask ko lang po ano yung difference nya sa previous vvti engine?
Sent from my SM-G930F using Tapatalk
Question lng mga Sir/Ma'am ung isang headlight ko kasi naninilaw may chance paba mabalik sa dating color nya?
mga sir ask ko lang bumili kasi ako ng 2015 head unit ng vios and nainstall na sa vios ko 2006 model.
upon testing ok naman yung radyo, bluetooth pati touch. problem pag clinick ko yung tilt baba yung screen pero yung tilt back greyedout tapos ung cd ayaw ilabas, usb di mabasa.
ask ko si seller about sa issue, as per him wala daw nung nakainstall pa sa vios nya functioning lahat.
sa tingin nyo po wiring kaya problem? tingin ko rin kasi wala talagang issue ang unit bagong bago pa.
[img]https://iak.*******/images_olxph/820841983_1_1000x700.jpg?bucket=09[/img]
Ask ko lang po kasi my odo now is 800km and it's nearing the firts 1k pms. Tomorrow we'll be going out of town and my estimate travel would be 400km.
My question is kung ma void ba yung warranty kapag ndi sakto sa 1k ako nagpa pms. TIA.
Kung may power and gumagana naman yun iba features, dapat lahat gagana. wala naman incompatibility yan sa lumang auto since separate device yan.
Subukan mo ibang usb storage device na mas maliit or yun mismong gamit ng dati may ari.
Parang pc lang yan na nilipat mo sa ibang saksakan.
Sent from my E5553 using Tapatalk
what you can do first, is to polish the outside first. see if there is improvement in illumination. if there is little or none, then i guess you have to polish the inner surface as well.
i also read somewhere here, that one needs to apply a sealant afterward, to prevent oxidation (again). if not done, the polish disappears fast.
i have polished mine, twice or thrice. the improved lighting wasn't as good as i wanted, and the polish disappeared after a few weeks. perhaps i need to polish the inside as well, and use that sealant also.
i also read of another method that used very fine grade sandpaper, then polish.
