View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 485 of 580 FirstFirst ... 385435475481482483484485486487488489495535 ... LastLast
Results 9,681 to 9,700 of 11582
    Jan 2014
    #9681
    Quote Originally Posted by midnytwarrior View Post
    So radiator + reservoir lang yun nilagyan nila. Total 2 liters less 60ml so mga 1.4 liters lang.
    So meaning hinde rin coolant replacement, simleng drain and fill lang ng coolant galing lang sa radiator. Pero yun sa loob ng engine hinde nakalabas. Yun new coolant mo contaminated na rin at wala talaga replacement
    Paano ba sir tamang replacement? Hindi ko pinanood nung sineservice. 60ml lang sir hindi 600. Gamit ko kasi syringe na 30ml. Naka 2 or 4 ata akong higop bago pumantay sa full line
    Apr 2014
    #9682
    Quote Originally Posted by luis_ View Post
    Ay uu nga pala. My bad. Hirap ng mahina sa math hehehe. Toinks!
    Tamang replacement lalo na sa casa is dapat may machine sila para makalabas yun coolant na naiiwan sa loob ng engine. Kaso baka sabihin ng casa na "hinde replacement yun kundi flush". Pero ang tanong sa kanila paano naman ang tamang replacement kung hinde lalabas yun nasa loob ng engine?
    So if wala sila machine na pang tanggal ng coolant is dapat aside from draining is dapat tanggal upper hose from radiator, i plug yun connection sa part ng radiator para hinde lumabas yun isasalin na coolant or distilled water. Start engine, put dist water muna until clear na yun lumalabas dun sa pinagtanggalan then premixed coolant then pag red na yun lumalabas sa hose na tinanggal eh shut off engine, reconnect the hose and start engine and refill as necessary. Medyo makalat lang at matrabaho, but since casa sila is dapat alam nila yan at dapat may machine sila. At more than 2L ang magagamit.
    Jan 2014
    #9683
    Ohh... Di ko kasi natripan panoorin mismo yung ginagawa pero ang napansin ko lang luminis sa engine bay ko e yung cover lang so malamang di nagalaw hose kasi dapat nawala mga alikabok nun. Thanks sa helpful post sir.
    Jul 2015
    #9684
    Thanks mga boss sa mga sagot tungkol sa 40k KM PMS!
    Mukhang ang nagpamahal eh ung labor na PHP3600 at mga Engine Treatment at Engine Decarbonize.
    Kelangan ba talaga ung mga un? Patulong mga bossing kung alin dito ung mga di ko na dapat pagawa. Salamat!
    Tsaka bakit PHP 3600 ung labor kaya..?
    May 2012
    #9685
    Quote Originally Posted by bambomboy View Post
    Extra lang yung engine treatment at decarbonizer, wala naman ata talaga effect yan sa engine. Ac ionize, engine flush and detailing kung ako hindi ko na isasama yan. Iba pa ba yung differential gear oil sa a/t gear oil, parang dapat a/t gear oil lang. Yung oil filter 450 na pala. San casa ka sir?
    Apr 2014
    #9686
    kelan nagkaroon ng differential yun VIOS?
    yun trans-diff nyan magkasama na at iisa lang ang langis. unless na lang rear wheel drive yan vios mo...
    Apr 2013
    #9687
    My 40K PMS was estimated around 16 to 17K pesos. After removing all the optional tasks, it went down to 6.6K pesos. Stuffs removed was alignment (since I will be getting new tires and will be needing alignment and balancing), treatment (I had a treatment last 35K), Premium wash (my car was clean inside out), air filter (I bought mine outside and said that I have a replacement waiting at our house), and many miscellaneous things. If you are on the tight budget like me, ask your advisor to remove all the optional maintenance and check your 40K PMS list from the manual. Sobrang laki ng nasave ko... And nagawa rin naman lahat ng required sa 40K, change oil and oil filter, change gear oil, change brake fluids, and check everything. Aircon cleaning will be done pag may budget na ako or pag hindi na comfortable ang lamig (init) sa kotse.
    Hello bossings, newbie ako hehe, kaya magpapatulong sana.
    Vios 2010 ung kotse. Tapos due na for 40k KM PMS. Previously puro casa ang PMS, pero ngayong nagpa quote ako ay nagulat ako sa estimate na binigay ng casa, PHP 21k.
    Tanung ko lang kung ano suggestions niyo, ituloy ko ba or hanap nalang ako ng ibang talyer? Out of warranty na rin kasi so baka hindi na ganun ka-important ung casa PMS.
    Thanks in advance!
    Jul 2015
    #9688
    Quote Originally Posted by SiPS View Post
    Sa Toyota Shaw sir. What about dun sa labor na 3.6k, ano masasabi niyo? Normal ba ito?
    Jul 2015
    #9689
    Yan rin pinagtataka ko sir, kasi nung niresearch ko nga kung ano ung differential gear oil, nakita ko na dapat same lang siya sa ATF.
    Normal na Vios lang naman ito, walang mods etc. sa pagkakaalam ko (kotse 'to ni misis kaya noob talaga ako sa kotse hehe).
    May 2012
    #9690
    I'm not sure about the labor cost, but maybe dahil maraming gagawin sa job order mo. Baka kapag pinatanggal mo yung mga ayaw mong services maybe bumaba din yung labor. But not sure about this.
    Jan 2014
    #9691
    2k lang dapat labor including tax. Kaso kasi dami nilagay sayo kaya yung mga extra na gagawin nila separate labor yun. Yung 2k included lang doon yung sa nauna kong post pero kunwari ipapa ac ionize mo, iba pa labor nun.
    Jun 2014
    #9692
    Tingin ko bababa yanpag pinatanggal mo iba. Un miscellaneous mo ang mahal 250. Sakin dati around 120 lang miscellaneous. Un brake cleaner ndi ba binalik sau dati nung last na brake clean mo sa kanila? Sakin binalik sobrang dami pa.
    Jul 2015
    #9693
    Naalala ko nung last year pala nagpa-maintenance ako, inoffer sakin ung linis daw ng aircon, nasa 7-9k yata un. Pag less than 40,000 KM daw, hindi na daw babaklasin ung aircon, may machine daw silang gagamitin pang linis. Pag lumagpas na ng 40,000 KM, babaklasin na daw, up to 3 days daw un.
    Tanung ko lang mga bossing kung nag avail rin ba kayo nung ganung klaseng aircon maintenance sa casa? Thanks!
    Jul 2015
    #9694
    Jul 2015
    #9695
    Naalala ko inoffer rin sakin ng Toyota Shaw nung huling maintenance ko last year na ipalinis daw ung aircon sa kanila, nasa 7k~9k yata, di ko maalala.
    Pag less than 40,000 KM daw, hindi na daw babaklasin ung aircon, kaya mas OK.
    Tanung ko lang mga bossing kung meron ba sa inyo nag-avail ng ganung klaseng aircon maintenance? Lapit na kasi mag 40,000 KM ung Vios namin. Thanks!
    Jul 2015
    #9696
    Quote Originally Posted by _incubus19 View Post
    Hindi binalik eh.. Wala, sobrang noob pa talaga dati, nung first 3 years ung nanay ng misis ko ang nagpapa PMS nung kotse.
    Jul 2015
    #9697
    Tsaka ano pala mas maganda mga sir?
    A) Use fully synthetic oil ng Toyota, then change oil after 10,000 KM
    or
    B) Use mineral oil ng Toyota, then change oil after 5,000 KM
    Thanks!
    or
    Thanks!
    Jun 2014
    #9698
    Ndi daw ok mag palinis aircon sa casa. Sabi din nila pag wala naman problema aircon mo wag mo ipalinis. Unless nalang kung 80k mileage na un car siguru kailangan na din palinis. Kung lumalamig pa naman ok pa yan. Ako 39k na mileage ko pero ndi pako nagpalinis ng aircon. Minsan may foul odor lang aircon. Off lang thermostat bago mag park wala na foul odor.
    Jun 2014
    #9699
    or
    Thanks!
    or
    Thanks!
    Mukang leaning towards sa casa ka na pa pms. Kung everyday mo ginagamit kotse mo pwede na semi-synthetic. Mas ok pa ata un kc at least 5,000kms palit ulit oil at oil filter. Mahal nga lang sa casa around 2.5k fully synthetic. Try mo combo zic a and baldwin bt223 oil filter. Mura lang zic a nasa 800php 4 liters na. Un baldwin nasa 290 ata not sure sa price. Dami nagsabi ok naman un combo ng dalawa. Last 2 change oil ko zic a (semi-synthetic) gamit ko. Ngayon zic a+ (fully synthetic). Parang nagsisi ako, mas gusto ko pa un semi-synthetic.
    Aug 2013
    #9700
    Sino pba may stock at seller ng bt223 dito?
Toyota Vios Owners & Discussions Thread
