View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 385 of 385 FirstFirst ... 285335375381382383384385
Results 7,681 to 7,700 of 11582
    Quote Originally Posted by Mask Rider Blac View Post
    Basag ung old tail light
    Naging brittle ung socket ng signal light
    Ung brake light nasunog/pundidoimg_20220624_185835.jpgimg20220624165659.jpgimg20220624165839.jpgimg20220624165831.jpg
    Sent from my CPH1911 using Tsikot Forums mobile app
    Combi light wiring harness PN# 81555-0D220, nagiging brittle un plastic over time and may special lock ang socket to seal from water kaya same replacement dapat ang ipalit mo. Around P1.5k yan sa casa pero nakabili ako sa Banawe isa shop lang meron for P150 - New Morning Glory Auto Supply, #15 Banawe St.
    Jan 2008
    Put some silicone grease onto the base of the bulb..
    Jul 2014
    Thanks a lot, Sir.
    Hindi pala 'to madali hanapin sa Laz of Shopee. Try ko sa mga auto shops.
    Jul 2014
    Transfer light bulbs to the new tail light.
    Jul 2014
    Jul 2014
    Test the lights.
    Test the lights.
    am i imagining it,
    that the reversing light is not white, but orange?
    camera default, siguro...
    Jul 2014
    am i imagining it,
    Hindi masyadong puti..parang warm white..
    Manilaw nilaw na puti (Hindi labas sa tide [emoji28])
    Jul 2014
    Ang hirap pala magtanggal ng screw kapag wala nang ulo. Kailangan ilabas much hangin from the tire then use flat screw driver para lumabas until ung dulo ng screw, then pull the screw with a long nose plier.Attachment 42063Attachment 42064Attachment 42065
    Jul 2014
    for some reason,
    i can't access the links.
    Jul 2014
    Posting picture, take 3..Attachment 42069
    Sep 2005
    invalid attachment..
    Jul 2014
    2013 Toyota Vios (2nd Gen) 2NZ-FE 1.3L
    After 10 years, na-lowbat din siya. OEM battery is Panasonic CR2016 Made in Indonesia. Replaced it with Maxell Made in Japan. The battery slot has a two-prong clip holding it in place; hence, might not be applicable to use bigger batteries like CR2025 or CR2032.img20230519213245.jpgimg20230519213827.jpgimg20230519214301.jpg
    Jul 2014
    2013 Toyota Vios (2nd Gen) 2NZ-FE 1.3L M/T
    159.8K kms
    Parts replaced:
    Stabilizer link (set) – Php1,020 (GMB)
    Tie rod end (set) – PhP940 (Kyb)
    Rack end (set) – PhP1,060 (Kyb)
    Ball joint (set) – PhP787 (Kyb)
    Shock mount with bearing (set) – PhP1,400 (Kyb)
    Shock mount washer rubber (set) – PhP700 (no brand)
    Bushing - suspension arm (set) – PhP1,500 (fabricated kasi polyutherane ung sa kanila)
    Rear engine support – PhP1,200 (fabricated kasi wala akong dala na bago)
    Total – PhP8,607.00
    Labor: (by Cruven)
    Engine support – PhP650
    Shock mount – PhP1,500
    Front suspension – PhP1,900
    Subtotal – PhP4,050
    Change oil and spark plug – PhP750
    Total – PhP4,800
    Sep 2025
    Hello po, 2025 vios xle new user po ako,1yr old na po, ubos na free casa service kaya im here to get help saan okay mag pa service? ung toyota shaw kasi mekus mekus trabaho kaya na trauma nko. looking din po ako cleaning services for interior and car wash na din, qc area, marikina, antipolo, pasig area po tysm
    Quote Originally Posted by daihatsuyota View Post
    Kung gusto mo maintain warranty kailangan sa Toyota-authorized i.e. casa mo talaga siya ipa-service unfortunately.
    Ano ba ang warranty period sa mga iba't ibang Toyota cars ba?
Toyota Vios Owners & Discussions Thread
