View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 489 of 580 FirstFirst ... 389439479485486487488489490491492493499539 ... LastLast
Results 9,761 to 9,780 of 11582
    Jun 2014
    #9761
    imageuploadedbytsikot-forums1439219571.011375.jpgimageuploadedbytsikot-forums1439219583.550016.jpgimageuploadedbytsikot-forums1439219593.471998.jpg
    Sa 1st pic, regarding coolant. Inspect at 40,000kms. Pero sa below note 4, change at 160,000kms then every 80,000kms after. Ganun ba talaga dapat?
    2nd pic, un brake fluid need to replace at 40,000kms. Pero sa 3rd pic, un clutch fluid puro inspect lang. Un brake at clutch fluid iisa lang un as far as i know. Correct me if i'm wrong. Anu un susundin dun? Change or not to change? Malinis pa naman un fluid ng brake pag check ko. Never pa ata bumawas laging nasa full.
    For manual transmission oil 3rd pic, as per manual no need to change puro inspect lang.
    I really appreciate your inputs. Now, hindi ko alam kung dapat na ba palitan un coolant, brake/clutch fluid and manual transmission oil. Base sa manual hindi naman kailangan. Please help. Thanks
    Apr 2014
    #9762
    Quote Originally Posted by _incubus19 View Post
    Sa coolant, if it says so in the manual na change at 160,000kms then so be it. As long as hinde sya na contaminate ng ibang coolant or na "water down" o ang paglalagay lang ng tubig para pandagdag so parang hihina yun timpla nun chemical nya.
    If it is required to replace brake fluid at 40,000kms, then replace it. Sana gawin ng maayos at tama.
    Sa M/T, pag hinde ka nmn nababaha o nabababad ang sasakyan sa tubig na aabot sa mga seals ng transmission at pag inspect eh malinis pa naman, then kahit hinde na, as per recommendation sa manual. Pero pag marumi at need talaga palitan, sana yun correct fluid ang ilagay nila (check the manual for specific type of fluid).
    Jul 2015
    #9763
    Sa pagkakaaalam ko sir magkaiba brake fluid sa clutch fluid.
    Sir pamessage ulit dito kapag nakapag palit ka na brake fluid. Kelangan ko na rin magpalit yata. Di ko naisabay last time kasi advise ng mekaniko di naman daw kelangan palitan, dinadagdagan lang daw un.
    Aug 2004
    #9764
    IIRC brake fluid can be used as clutch fluid but a car uses two separate reservoirs and the systems are not linked.
    Feb 2015
    #9765
    query lang po mga sir regarding casa maintenance sa mga nababasa at nakikita ko po sa mga thread regarding their 10k pms subject for replacement na po yun spark plugs natin pero base on the manual clearly stated it was need to be change at 40k km pms, any idea how long is the life span of toyota oem type spark plug imageuploadedbytsikot-forums1439291272.046449.jpg
    Quote Originally Posted by mcdip View Post
    40k - platinum tip yan. Hampasin mo yan service adviser na yan with the owners manual.
    Or lipat ka sa ibang service center
    Jul 2014
    #9767
    Maraming arguments din pg dating sa spark plugs. May mga plugs na after 10K humihina na (?). Si SA, since may commission sya, bebentahan ka kaagad pg naka 10K ka na. Ang maiiging gawin ay monitor mo ung fuel consumption mo.
    Below is fuel economy tips by Phoenix saying don't use plugs beyond 10K.
    Fuel Efficiency
    ...pero hndi ko sinusunod yan. Lalo na sa motor ko nililinis ko lang ng alambre.
    Jan 2014
    #9768
    Hindi ko rin pinapalitan nung 10k ko kaso nagbasa basa ako sa forum ng mga vios lahat sila nagpapalit every 10k. E gaya gaya ako dahil di pa naman ako marunong gaano...
    Eto nga pala akin last palit. Ok pa, normal naman daw based sa nababasa ko sa net kaya balak ko next time hindi na every 10k. Check na lang muna talaga. Iniisip ko ipapalinis ko na lang pero nagbasa ako kung paano maglinis mukhang hindi nila gagawin haha.
    Jun 2005
    #9769
    mura lang naman ang spark plugs. sakin i just replace when i feel like it.
    Apr 2014
    #9770
    Normally pag platinum o iridium plugs umaabot ng 100,000 KMs. As a safe bet kaya ginawang 40,000 KMs as recommendation para laging fresh at syempre drving habits na rin ng vehicle owner. Pag copper plugs, un mga sinauna pa, kadalasan 5,000 KMs lang, pinakamatagal na ang 20,000 KMs. Isa pa pag sobrang tagal na hinde napalitan eh baka mag stuck na yun plug at minsan nagkakataon na napuputol pag tinanggal na.
    Nasa 2 years na rin ba auto mo o 24 months kaya siguro ni recommend na nila?
    Jun 2014
    #9771
    Quote Originally Posted by midnytwarrior View Post
    For coolant, nag top up lang ako ng super long life coolant pre-mix (pink) and sa casa ko binili.
    For brake fluid, ang napanuod ko lang sa youtube is tinanggal lang un fluid sa reservoir tapos nilagyan ulit ng bago. Anu un proper way to change brake fluid? Not changing my break pads. Alam ko lang un drain un old fluid sa reservoir (nakita ko sa youtube). Un mas complicated na way hindi ko na alam.
    For M/T, dati nalusong ko sa baha un car mataas un baha. Kahit last 2 months nalusong ko din sa baha. Pero last time na pinacheck ko un M/T oil sabi malinis pa. Chineck kasi may squeaking sound pag nag change ako ng gear. Un pala kulang lang sa lubricant.
    For the specific type of fluids, sa casa naman ako bibili so siguru un ibibigay nila is un recommended fluid.
    Jun 2014
    #9772
    Quote Originally Posted by bambomboy View Post
    Sige sir update ko dito. Sa reservoir kasi ng brake fluid same nadin un sa clutch. Pero mas nalinawan ako sa sinabi ni JohnM. Problem lang hindi ko alam anu un proper way para palitan ang brake fluid. Hehe
    Jun 2014
    #9773
    Sir san makikita un clutch fluid reservoir? Ang alam ko lang un sa brake fluid reservoir. Sorry for the noob questions.
    Aug 2004
    #9774
    Nabasa ko sa Gen 3 thread na iisa na lang pala ang reservoir for both clutch and brake sa kanila. Baka sa Gen 2 ganun din. Can't personally check dahil AT ang Vios ko. Try looking for it in the user manual.
    Feb 2015
    #9775
    maraming salamat po sa mga inputs nyo mga maestro, sir midnytwarrior 6 months pa lang po advance reading and research lang ako pgdating sa mga pms kaya ko pa naitanong regarding spark plugs, getting ready for the present
    Jul 2010
    #9776
    Mga Sir, Quick question and advice lng, tom ilalabas ko vios ko sa Casa. almost 1month sya dahil sa repaint ng almost whole body( insurance claim) anu ba need ko echeck bago ko ilabas. maliban sa paint. like parts na baka pinalitan o kinahoy nila. due to long stay sa Casa. thanks
    Jun 2014
    #9777
    Noted. Thanks sir
    May 2012
    #9778
    Medyo nalilito rin ako diyan kasi dun sa far right may naka-indicate na number of months. Is it the same with the engine oil na whichever comes first? Like sa manual transmission oil na puro inspect lang pero nakalagay na 48 months, does it mean na it must be replaced on the 4th year?
    Apr 2014
    #9779
    Quote Originally Posted by SiPS View Post
    Bale Sir, pag indicated na replace (R) under sa line ng mileage, means replace din po yun indicated under sa column ng "MONTHS"
    So makikita ninyo na may mga cases or situations ng isang item na meron nakalagay under sa MONTHS eh I:24 R:48 na nakatapat naman under sa column ng mileage na meron I then followed by R.
    Like sa valve clearance eh inspect (I) under sa last na mileage lang tapos 96 under months. So inspect lang sya sa 96 months.
    Sa manual transmission naman, puro inspect lang pati at 48 months inspect lang sya. So, yes same ng engine oil na whichever comes first - indicated na every 10k or 12 months.
    Jun 2014
    #9780
    Ganun pala un. Salamat sa explanation. Hirap kasi intindihin. Hahaha Un iba nakakapagtaka puro inspect lang.
Toyota Vios Owners & Discussions Thread
