Page 33 of 43 FirstFirst ... 23293031323334353637 ... LastLast
Results 321 to 330 of 424
    #321
    thanks for the info. franklyn trading na pangalan nito sa better living. ito ba 'un? as far as my water pump is concerned, matibay at walang problema. i just go there for freon (r12 for liteace).
    sa servitek ako nagpapacheck ng suspension. pero 'ung last na gawa ng suspension ko sa cruven sucat:
    Suspension Labor = 1,400.00
    Repair Rack End x 2 = 700.00
    Repair Upper Ball Joint x 2 = 700.00
    Repair Lower Ball Joint x 2 = 700.00
    Repair Tie Rod x 2 = 600.00
    Repair Stabilizer Clamp Bushing x 2 = 500.00
    Steering Boot x 2 = 360.00
    plus:
    Front Shock Absorbers x 2 = 1,600.00 bought at cruiser, sucat road
    #322
    Iyong sa jet malalaman mo pagpinalitan na kung hindi na stock ito o pinalitan ng mas maliit ang butas . Sa mga carburator specialist alam nila kung stock pa o hindi pag binuksan nila carburator mo. Pa check mo na lang kung pinalitan ng mas maliit ipabalik mo sa stock mura lang naman jet.
    #323
    Quote Originally Posted by onewaytrip View Post
    have the distributor o-ring (~100 pesos lang ito) and oil seals checked for leaks. sorry wala pa akong experience sa overhaul since di ko pa naman kinailangan. religious ang palit ng oils at fluids. i'll just share with you regular maintenance items that i use/used.
    regular oil change: shell helix ultra, vic oil filter (nothing beats a well-oiled machine )
    petron gas saver (hinahalo sa gas, ~php50-php80 depende sa station) once a month or once every two months
    genuine air filter, condenser, contact point, and denso spark plugs from toyota auto supply (e.g. cruiser at sucat road) or from casa
    toyota transmission oil and coolant from casa
    tires are 185/70-13 (bridgestone ar10)
    ano po yung distributor o-ring? and ano po pang check mo sa oil leaks? :P baka kasi di ko naman kailangan ng overhaul :P ano ba ang mga cause bakit bumabawas yung oil sa engine?
    #324
    the distributor o-ring is a small ring-shaped rubber gasket on your distributor, about the size of a 5-peso coin. just like the other oil seals in the engine, the distributor o-ring gets brittle and hard over time, allowing oil to seep through.
    to check for oil leaks, it's best to have a mechanic take a look under the engine bay.
    Aug 2009
    #325
    *onewaytrip...oo bro yan nga yung shop halos tapat yan ng PETRON...
    bro try mag log in sa www.liteaceclub.com my handle is "747-4"....
    #326
    Maraming dahilan bakit nagbabawas ng langis ang makina .
    1. kung may mga leak ang mga gasket kagaya ng oil pan, Valve cover,
    2. Sa makina valve seal worn out na kaya kumakain na ng langis ang makina kaya mausok na ang tambutso ng sasakyan pag tumatakbo ito.
    Aug 2009
    #327
    external oil leak / possible suspect are :
    . o-ring sa distributor
    . oil seal sa crankshaft
    . gasket sa oil pan / valve cover
    . oil filter
    pero kung nagbabawas pa rin at wala kayong makita sa external.....
    malamang e internal problem na yan / possible suspect are:
    . worn piston rings / valve seals
    #328
    Pinapagana ko na yng liteace ko. Kakabili ko lng ng carb grabe 10500php sya ang mahal. Sana mag ok na ang makina. Btw alam nyo ano yng starter solinoid natin? I mean ano model? Mali kasi yng sa iba eh.
    #329
    anyone who knows where can i fix my suspension? pinaayos ko na to before pero ganun pa rin... yung buong joint raw ata yung sira pag nag tuturn ako lagi may tunog... sabi naman ng iba sakin ball joint lang..... kailangan ko na pagawa sa magaling to para hindi ko na pagawa to yearly....
    Aug 2009
    #330
    Quote Originally Posted by quest_uy View Post
    mga bossings.... san shop ba pwede dalihin ang liteace? dami dami ko na kasing shop dinaanan neto pero may problema pa rin sa suspension and makina eh. may marerecommend ba kayo? tiga manila paco po ako... umabot na ako hanggang sucat para paayos to.
    sir yung lite ace ko sa antipolo ko pinagawa overhaul pati pangilalaim ok sila dito maayos at may warranty ang trabaho kung gusto mo lang subukan dito sa antipolo ang pangalan ng shop ay BEN Motorworks corner ng sumolong at circumperencial road
    eto yung number nung may ari
    niel pantaleon
    smart-0930-4375050
    landline-02-5141820
    lito jimenez ang pangalan ko dun ako palagi nagpapagawa
Toyota LiteAce Owners & Discussions Thread [Merged]
