kung chassis number nasa passenger side malapit sa front wheel. ang mahirap yung engine number.nasa ilalim ng just above the oil pan. driver side.
Has anyone installed an AVT 2 din + rear camera? How much does it cost? and which particular AVT model would you recommend?
WBR,
Hello fellow tsikoters! Saan ba makakabili ng touch-up paint? may part doon sa Innova ko na mdyo nawala na ung paint. May color code pa ba ito? or the color beige mica metallic shall suffice? TIA.
WBR,
Hi guys! ... Any new innova owners out there noticed na nag squeak yung brakes kapag inaapakan yung brake when going downhill after a cold start up? ... Sa condo kasi kami nakatira so pag aalis kailangan bumaba ng rampa and i noticed nag squeak yung front brakes ko . But my mileage is only 3,000 kms so medyo bago pa. Is this normal? ... Kapag pantay naman road, wala namang squeak
Umagang kay ganda sa Commonwealth Avenue! Na-sandwich dahil sa biglang preno ni lady driver sa unahan! Thanks God at walang nangyaring masama kay misis 5months pregnant at walang nasaktan sa amin.
guys help naman. pag kita ko sa hood ng innova namin madami talsik ng kalawang, mga maliliit na dots. ayaw na maalis.
matatanggal pa kaya ito sa buffing? or any advise para matanggal ito? Thanks.
If the hood spot is underneath the battery, it is possible that it was all splatter from the battery breather holes (low maintenance battery). If that is the case you can not do anything about it, battery acid solution already eats up the paint in those small dots - repaint is the solution.
Had the same situation, that's why I replaced my battery to maintenance-free since then.
