Page 582 of 775 FirstFirst ... 482532572578579580581582583584585586592632682 ... LastLast
Results 11,621 to 11,640 of 15487
    #11621
    Quote Originally Posted by yach022 View Post
    mga ka innova, umilaw un fuel filter ko kahit puno naman un gas ko, nagpalit na po ako ng fuel filter pero ganun pa rin po. matagal na po ako sa labas nag papachange oil.
    anu po poblema kaya po?
    Innova 2015 J diesel po un akin.
    Thank you mga master
    someone already described here, step by step, how to turn that filter warning light off. use the search engine to find it, sir.
    when that happened to me, i replaced the entire fuel filter assembly in disgust. at that time, the procedure i mentioned hadn't been uploaded yet..
    good luck.
    #11622
    Still under warranty? Better have the casa fix it.
    #11623
    nangyari din sa akin ito few months ago. nag research ako ng konti sa you tube. i check the MAF sensor akala ko madumi, kita pa naman ang metal kaya hinde ko na ginalaw, then nung binalik ko yung connector simula nun hinde ko na na experience yung fluctuation ng RPM. siguro na reset yung connection sa ECU. ingat lang sa MAF sensor at sensitive ito, it needs special cleaner at hinde pwede ang carb cleaner.
    Quote Originally Posted by robbie26 View Post
    Need help with my 2008 Innova E Gas AT...
    I noticed that my RPM is fluctuating (parang nawawalan ng power). It usually happens when I'm cruising at a steady pace in low RPM.
    I also experienced it several times upon starting the engine. Normally, when we start a cold engine mas mataas talaga yung RPM until the temp normalizes. But it stays right above 1000rpm until it eventually goes down to its normal rate. But sometimes, I experience heavy fluctuations ranging somewhere between 500rpm to 2500rpm.
    What could be the problem? Is it my battery or my spark plug?
    Feb 2006
    #11624
    i have been using mineral oil for 10 years and over 110K km now. engine still works fine..
    tnx po sir dr. d, yun po fuel filter kelan po kayo sir nagpalit
    #11625
    Quote Originally Posted by jovz View Post
    i replaced the filter early on.. perhaps less than 20K, because the warning light flashed. i read the manual... baka may tubig daw.. i first did the pumping away, to no avail. so i changed the filter. ganun pa rin. not knowing what else to do, i replaced the entire filter and holder assembly. nawala ang ilaw finally. and i haven't replaced the filter again, even after more than 100K...
    years later, somebody posted here how to kill that light, by doing "electrical skullduggery"...
    Feb 2006
    #11626
    ah napansin ko lang po kasi nun nasa slex kami pag abot ng 100km sa odo parang sagad na yun takbo niya
    #11627
    baka nga sagad na..
    also, if the fuel filter is clogged, it may show up during high speed running, and not in slower speed running..
    i have not yet gone faster than that in my diesel innova, because of my "bad heart" and "defective right foot"...
    Feb 2006
    #11628
    baka kako may problem na sa clutch system kaya hanggang 100 na lang
    #11629
    is the silinyador floored, already?
    perhaps if you remove the mat, you can further depress the pedal...?
    it happened to me before.. didn't go as fast as it did before.. i found out that the second mat i put in, was in the way.
    (i didn't want to subject the original mat to wear and tear, hence the cheap mat i installed..)
    Mar 2015
    #11630
    un sa akin innova e a/t 130kph sa slex kaya pa ako lang umayaw baka mahuli 6 adult sakay ko
    Feb 2006
    #11631
    ang innova po ba need din ipa tune up yung bubuksan yun ibabaw ng engine
    #11632
    valve clearance adjustment?
    dunno..
    Jan 2014
    #11633
    Try replacing your fuel filter it may be dirty/clogged
    Haven't experience that with my m/t diesel innova.
    Is it a manual or a/t?
    Feb 2006
    #11634
    sir mt po un innova, baka nga po need na palitan filter
    Jan 2012
    #11635
    kung di na kuha sa pagpalit ng fuel filter, clogged fuel pump na po yan. changed mine after 80k
    Feb 2006
    #11636
    tanda niyo pa po ba sir kung mga magkano po fuel pump baka sakali lang dn
    Jan 2009
    #11637
    Don't just blindly change parts without going through the motions of diagnosing it first. If the pump and/or fuel pressure regulator is faulty, it won't give the correct pressure. So the obvious step here is to check the fuel pressure. If the pressure is within specifications, then you'll know that the problem is elsewhere.
    #11638
    how does one check pressure?
    May 2009
    #11639
    with engine off, hugutin yung electrical connector sa may fuel filter-priming pump assembly.
    with key on "ON" position, pagkatpos ng ilang segundo lang (2-3 seconds or more pa siguro) e ireconnect yung tinanggal na electrical connector.
    kung ayaw pa rin mag-off. subukan mo uli.
    kung ayaw talaga, takpan mo na lang ng tape yung tapat nung ilaw.....joke lang.
    Jan 2009
    #11640
    A well-equipped mechanic or casa service center will have the necessary tools.
Toyota Innova Owners & Discussions [continued 3]
