Kapag steady yung ilaw ng indicator, it means nagbabara na fuel filter. you just need to replace the fuel filter element. Meron video sa youtube on how to open the filter housing, search mo nalang.
On how to reset the indicator light after replacing the filter element:
1. With your engine off, disconnect the 2 sensors sa fuel filter housing, one on top, one on the side. No need to disconnect the battery.
2. Turn your ignition key to "On" position so all of the gauge indicators light up.
3. Within 60 seconds, reconnect the 2 sensors you disconnected earlier.
4. Check the fuel indicator light, it should turn off.
5. Start your engine normally.
HTH.
HTH.![]()
Good day mga ka tsikot (Innova), thanks sa mga advise nyo and finally decided at kalalabas lang nang Innova 2.5 E Diesel A/T namin and my family love it, ganda hatak, tahimik and FC is good 11-12 km/l using Unioil from Manila. Hingi sir nang advise, my son felt Unioil is okay and as advise by the casa, kaya lang wala dito sa Pampanga o Angeles City.. Is Shell V-Power + Nitro Diesel okay as 2nd option or any other suggestion. Thanks
dati petron user ako at unioil. ang ayaw ko sa petron, kung bihira highway driving, may time na matamlay, may time na responsive, kumbaga, hindi siya consistent unlike ng unioil.
pero nung sinubukan ko yung shell diesels (fuel save at nitro +), kahit mostly city driven lang, consistent yung responsiveness niya at fuel consumption (8 to 10 km/l city; 14 to 16 km/l highway - Paranaque to Sta Clara Batangas - 180kms balikan).
based on experience lang ito paps, baka sa iba, iba din performance pero kung ako tatanungin, ok na ok yung shell diesels.
sa mechanical diesel naman namin (hilux - 2L engine), kahit anong diesel bukod sa Caltex, ok na ok siya. hindi masyadong choosy![]()
Normal yan. Tulo ng aircon yan.
Since dual AC ang innova yun tulo galing sa rear evaporator which is located exactly dun sa right(passenger) rear side.
No prob!
Congrats and enjoy your innova sir!
1 month owner. Originally Shell fuelsave diesel ang gamit. ang tanong ko mga bossing, kung sakali lang magipit, ok lang ba diesel ng iba ang ikarga? Wala ba masama epek yun? TiA!
mga expert, question lang po re fuel filter warning indicator. The indicator remains lighted even after replacing the fuel filter with a new one.
My unit is 2.5 E manuel diesel with 36k km odo reading. The filter was replaced sa suking talyer. They tried resetting the indicator light by removing the negative terminal of the battery and truing the ignition to "on" for 10 sec pero may warning light pa dinTIA
mga expert question lang po re fuel filter warning indicator. The indicator remains lighted eve after replacing the fuel filter.
ok na guys
i read somewhere.
turn key to on.
remove the 2 connectors of the fuel filter.
after about 3 or 6 sec, re connect again.
then off the ignition. Start engine and problem solved
ok na guys
i read somewhere.
turn key to on.
then off the ignition. Start engine and problem solved![]()
Anybody who has installed DRL on his Innova? Anything in the market that is tailored for the Innova? Where and how much please? Thanks!
Mga innova guru, curious question. Sabi sa brochure, Innova has 4-speed AT Gate-Type with ECT. Any idea about "ECT" ?
Tried to search in google, ECT seems to be "Electronically Controlled Transmission", but most search results mentioned ECT button, but our innovas does not have any ECT button.
Any other helpful info regarding ECT? Thanks and more power!
Any other helpful info regarding ECT? Thanks and more power!![]()
ibig sabihin paps, ECU controlled ang shifting ng automatic transmission kapag sinabing ECT, compared sa mas conventional AT ng toyota na inaadjust yung shift point ng automatic transmission sa cable tension ng tranny, tulad ng sa mga corolla bigbody gli dati.
Thanks po innova2013. ECU controlled pala ang ibig sabihin ng ECT.
Thanks po innova2013. ECU controlled pala ang ibig sabihin ng ECT.![]()
good am. sa manual transmission po na innova, and gamit po na ba fuilds (and /or lines) ng brake and clutch ay iisa lang?
tia
tia
May new innova with new engine pala na lalabas late this year(?)... Sana better performance more reason para mag-ipon pa hehe
May new innova with new engine pala na lalabas late this year(?)... Sana better performance 😃 more reason para mag-ipon pa hehe
Good Evening mga ka tsikot..
We own a Toyota Innova E 2.5 Diesel Manual Transmission 2015. And 1st car namin po to. Pahingi namang ideas para sa accessories at mga dapat na maintenance ng car namin..
From Laguna kasi kami.. So san kami makakabili ng accessories na affordable ang presyo.. Presyong ginto kasi sa Toyota Calamba e.. Then wala pa kaming alarm ang singil sa amin e 6k for alarm (Toyota Calamba) meron dito sa amin sa 2.5k. Mas nauuna ba talagang mapaso ang warranty bago ang Electrical nito?
About naman po sa maintenance. Anong pang linis ang gamit nyo?
And kapag nagrereverse po ako para may naririnig akong nahugong (sound like turbo) kapag mabilis po yung reverse. Normal po ba yun?
