Page 519 of 775 FirstFirst ... 419469509515516517518519520521522523529569619 ... LastLast
Results 10,361 to 10,380 of 15487
    Oct 2013
    #10361
    Quote Originally Posted by maze View Post
    Nahihirapan ako pumili.... Toyota innova variant G AT year model 2008 gas.. Owner selling price is 450,000 php odometer nasa 50k -60k. Hindi tampered my casa record. Fresh at sariwa alagang alaga. At isa pa na toyota innova varian E AT model 2011 gas.. Owner selling price is 480,000php odometer nass 50k-60k. Hindi rin tampered my casa rexord fresh at sariwa rin. Hard to get. Ung mas latest year but E or old model but G, hirap magdecide... Kung alin sa dalawa bibilhin ko. But the 2 unit is ok naapreciate ko cxa.
    Get the 2008 G AT. Mas gamit yung 2011 model, ang average run dapat ng sasakyan is 10k per year, yung 2011 model dapat around 30k to 40k km lang.
    Mas maganda ang trim ng G, pero di ko lang type ang beige kasi dumihin ata.
    #10362
    Stock ba ang E? Or were there upgrades to it?... They have different grills and rear design. And the features of the 2011 E have been upgraded by Toyota.
    20kkm a year is where we are on mileage, total. For individual rides, it depends on how many a person owns and what is the owner's preference.
    Oct 2013
    #10363
    Kung kaya mo pa tawaran yung E, hangang 450k, sa 2011E ka na kasi mas bago pala looks ng E hehehe...
    Anyway, most of the time ang tawaran nyan ay halfway sa butal, so mga 465k labas nyan.
    Jun 2011
    #10364
    Hello po, this April, nag start mag pop-out from 3rd gear ang manual transmission lever namin. Later pati 1st gear laging nag-slide out sa slot niya. When changing or shifting gears, you need to give it an extra push to the gear slot, or hold it in position. Otherwise, the 1st or 3rd gear will slide out in the middle of the shift. Buti I found this link:
    Toyota Tacoma manual transmission pop out of gear? Here's the simple fix!
    Transmission now works like new. =)
    http://www.instructables.com/id/Toyota-Tacoma-manual-transmission-pop-out-of-gear/?ALLSTEPS
    Jun 2011
    #10365
    Unit pala namin Innova E VVTi Gas MT. Heto pala ang parts na kailangan. Order lang sa any Toyota CASA, 3 days to arrive ang part.
    - Shift Lever Bushing: ~Php 30020150425_074051.jpg
    - Shift Lever Seat : ~Php 500
    Jun 2011
    #10366
    No need to remove the whole console box. Clips lang sa upper half na console. No screws to remove. Attach image of upper console removed. Kita na nandoon pa ang lower half niya.20150425_084928.jpg
    Jun 2011
    #10367
    After removing na upper screw cap, Similar doon sa Tacoma na thread, kita na durog na durog ang upper half ng Shift Lever Seat:
    Jun 2011
    #10368
    Sa previous post pala, may naiwan pa na black gasket na lower part, kailangan i-remove din ito at linisin ang area.
    Vaccum din ng loose parts. See Tacoma thread.
    Heto naman pix na shift lever bottom area, cleaned and old white cap/bushing removed:
    Jun 2011
    #10369
    Heto naman ang new seat installed:
    The rest ng steps, similar na sa Tacoma Thread. Ayos na ang tranny namin. =)
    Apr 2015
    #10370
    Is that the pinkish one?
    where can i buy?
    Hello po.. newbie lang po.. may binili kaming toyota innova 2007 model at gusto naming palitan yung radiator coolant, alam ko na dapat 'Toyota Super Long Life Coolant, but the problem is HOW MANY LITERS PO?" please pa advise po.. salamat po.
    #10371
    Quote Originally Posted by biboypalaboy20 View Post
    What model is your Innova? Gas or diesel? Manual trans or auto?
    Based on the owner's manual:
    Gasoline manual trans: 7.0 liters (w/out heater)
    Gasoline automatic trans: 7.3 liters (w/out heater)
    Diesel manual trans: 9.0 liters (w/out heater)
    Diesel automatic trans: 10.3 liters (w/out heater)
    #10372
    errr... the previous owner didn't give you the owner's manual?
    how inconsiderate of him..
    Apr 2015
    #10373
    Quote Originally Posted by CivicVTi View Post
    Thanks pards Civicvti, bale Toyota innova 2007 automatic/Gas. Salamat sa info laking tulong nito sa pag palit namin ng coolant, meron akong pdf file ng innova 2005 manual (na download ko lang sa inet, wala kasing binigay na manual yung may ari) at di naman naka indicate kung ilang liters ng coolant kung i-flush lahat.
    Thanks ulit pards..
    Thanks ulit pards..
    Oct 2013
    #10374
    please help for 10k pms na po ako. lalabas na po ako ng CASA ok lang po ba kung shell tapos un mga filter ay OEM na lang bibilhin ko. anu po recommend nyu na engine oil. salamat po! innova diesel po un akin.
    Aug 2013
    #10375
    Quote Originally Posted by yach022 View Post
    kung may takot ka na baka mali ang mabiling mong oil at oil filter para sa innova mo, pwede ka namang bumili ng oil at oil filter sa toyota. tapos sa gas station mo na lang ipa service.
    same procedure din naman kung basic oil change and inspection lang ang gagawin.
    HTH
    HTH
    #10376
    i go to the gas station that is offering an oil change promo. hindi naman siguro sila magbebenta ng peke na langis, dahil pangalan nila ang nasa lata..
    Oct 2013
    #10377
    Quote Originally Posted by innova2013 View Post
    HTH
    HTH
    ah ok po sir. anu po ba recommend nyu na engine oil ? diesel po ako po.
    #10378
    Do you still have the owners manual? andun mga recommended oil.
    Oct 2013
    #10379
    sa 10k PMS po ba anu po usually papalitan? sorry un manual ko kasi naiwan ko po sa province namin eh nasa manila po ako ngayun. salamat po.
    #10380
    Based on the manual, the diesel variant requires G-DLD-1, API CF-4 or CF (You may also use API CE or CD)
Toyota Innova Owners & Discussions [continued 3]
