Page 231 of 775 FirstFirst ... 131181221227228229230231232233234235241281331 ... LastLast
Results 4,601 to 4,620 of 15487
    Oct 2011
    #4601
    Quote Originally Posted by vic2rem View Post
    2010 Innova Gas A/T with 36K . Gas has timing chain, Diesel has timing belt. Every 10K casa pms, cost under P1,700++ cost with my own oil and iridium plugs plus bought a/c filter for P950++ and brake pad changed during 30K pms, P2,200++. Only problem was leaky shocks fixed under warranty.
    I see. Can anyone share po pms costs ng diesel? I know na 5k pms ang disel, para lang po macompare ko dito sa gas. We're planning to have a 7 seater by march 2013 pa naman. Pero, nagsscout na ako ng options namin. Diesel sana kaso this will be our first bnew if ever so gusto ko makita ung pms costs and fuel consumptions.
    Thanks again!
    Oct 2011
    #4602
    Quote Originally Posted by mr_x View Post
    Took Marcos (Aspiras) Highway both up/down.
    I don't know about "lots of sound insulation" but have ride with our company van using innova diesel and my gas innova and truly big difference.
    I also put in my innova the hood insulation (to have less heat in the hood and also reduced noise, i think this is only installed in diesel).
    Here's my current gas consumption (this is actual and not anyway via MID reading), i'm monitoring using apple apps (nice apps) every time i gas up i put up the odometer reading, the liters and the price as well.
    So far average of 9.4 km/L (just about less than 2k km ODO):
    Sir, magkano po damage sa hood insulation and san po kayo nagpakabit? Malaki po ba ang nawalang ingay?
    #4603
    mga sir..patulong lang po..newbie lang dito at first time magkabrand new car(innova e)..tanong lang po sana kung ano magandang wax pangmaintain ng sasakyan para sa windshield tsaka ung sa exterior ng sasakyan..pati na rin po sa dashboard..salamat!
    #4604
    Quote Originally Posted by blackmamba58 View Post
    Taga dito din sa tsikot, search mo na lng hood insulation.
    Wala akong pang measure ng noise but definitely quiter than before.
    #4605
    I think ang hood insulation ay primarily para hindi masyadong mababad sa init ng makina ang hood ng Innova...
    17.3K:type:
    Aug 2008
    #4606
    ask ko lang po kung sino po ang naka experience ng loss power pag nag overtake tapos nag oover-rev ang engine, innova G po na gas/at ang unit ko,
    Apr 2012
    #4607
    17.3K:type:
    Sang ayon ako kay Sir CVT. Nag drive ako dati from Pampanga to Bulacan ng gabi. Up to 100 kph ang inabot ko pero walang kainit init ung tapat ng insulation sa hood ko. Nagtaka pa nga ako kung baka may sira ung makina na at baka di masyado umiinit.
    #4608
    17.3K:type:
    Exactly, pero actual may reduction talaga (although subjective kasi walang gauge).
    Parang beat box (yung square box the pinupukpok), now try putting insulation sa loob ng beat box and see kung may effect sa sound)
    May 2005
    #4609
    D-4D dsl needs a hood insulation bec. its emits more heat than the VVT-i gas.
    #4610
    Quote Originally Posted by boorat View Post
    Never experienced over rev ang engine at D... nag oover rev lang pag nasa L, 2 or 3.
    Aug 2005
    #4611
    Gaano kataas umabot pag sinabi mo na over rev? para sa akin kasi ay red line ang ibig sabihin ng over rev.
    sny way, wala naman akong napansin na ganyan sa m/t innova namin,
    #4612
    Baka naman ang sinasabi mong "loss of power" during overtaking ay iyong pag-downshift ng A/T, - at ang overrev ay iyong mataas na RPM dahil nakadiin ang paa mo sa gas pedal (dahil nga overtaking mode ka)... It's normal for A/T rides to act just like that....
    17.3K:type:
    Jul 2003
    #4613
    I understand some people want to protect the hood. But adding insulation will decrease heat dissipation right? The more heat the engine produces, the more you want the heat to be taken away from the engine bay. Additional insulation probably will protect the hood but it won't help is dissipating heat.
    Aug 2008
    #4614
    redline po, napansin ko po kasi nung minsang nag overtake ako tapos full press sa accelator biglang nag over rev, ayaw nya mag shift (automatic po ang unit ko), ang ginawa ko release ng accelator then press again saka lang siya nag shift, newbie kasi ako sa automatic transmission, mag problema po ba ang transimission ko?
    Aug 2008
    #4615
    17.3K:type:
    worried lang sir baka may sira, newbie kasi ako sa automatic, may nagsabi sa akin na laruin ko daw ang pedal para maka buwelo
    #4616
    No worries bro.,- if what you've experienced was something similar to what I described,- then it is perfectly normal.
    (I know that because I do it a bit often...(and I have two more A/T rides(other than my Innova Gas A/T) behaving just like that )....
    17.3K:type:
    Feb 2009
    #4617
    just bought 2013 model toyota innova J Diesel here in baguio last October 31, 2012. i have two questions to ask:
    1. my innova emits white smoke sa umaga pag paakyat ako. paakyat po kasi yong kalsada palabas sa garahe ko. i observe a lot of white smoke until such time na nakatakbo na ako ng around 2 kilometers kahit na naka pre heat yong innova before i start driving. is this normal for a brand new innova during break in period?
    2. i rescently discovered that the warranty booklet na binigay sa akin ay nakapangalan sa ibang tao with the same engine number, serial number and conduction sticker. what does this mean?
    Aug 2008
    #4618
    ingat pala kayo pag nagbiyahe kayo sa real, quezon, nagka dimple ang unit ko
    #4619
    Ano ba iyan bro? May tumalsik na bato sa kalye dahil nagulungan ng ibang sasakyan?
    O, may nambabato?
    17.3K:type:
    #4620
    Quote Originally Posted by kuligligko View Post
    May date bang nakalagay sa Warranty Booklet?
    I-check mo rin ang iyong Delivery Receipt and other documents at baka ganoon din ang kaso, bro....
    17.3K:type:
Toyota Innova Owners & Discussions [continued 3]
