Results 9,601 to 9,610 of 13229
March 10th, 2009 09:35 AM #9601
- Jun 2008
- 50
March 10th, 2009 12:13 PM #9602my nakita ako sa casa na grill strobe light o blinker, whatever
it will cost 8,500.. naka install sa LC200..
March 10th, 2009 05:17 PM #9603
Mga innova gurus, tanong lang po..pls
Bumili ako ng gamit na gulong sa kapitbahay ko (makapal at mura kasi)
size is 205/70/15" medyo mas makapal sa stock na 205/65/15".
Ang tanong (No. 1) may epekto ba to?
2005 innova G gas m/t yung sa akin. Kaka-acquire ko lang. Hindi ko alam pano yung gamit ng dating may-ari pero mukhang ok naman.
So far, pina change oil at palit ng air at oil filter pati spark plugs. Yung fuel filter hindi pa napalitan, medyo mahal kasi. Pina-align and balance ko rin.
Ang tanong (No. 2) ano ang dapat ipa-check ko at dapat ba ako magpalit ng fuel filter?
Malamig pa yung aircon at gumagana naman lahat ng electronics, kaso yung 3rd brake light sa gitna/taas hindi na umiilaw...may nabibili ba nun?
Thanks po
March 10th, 2009 06:07 PM #9604
Medyo tataas lang ng mga 1 inch ang body ground clearance mo. I have seen some Innova's on 204/70/R15, have talked to some also and they say ride comfort has improved.
Every 5Kms palit ng engine oil (mineral) and oil filter
Every 10Kms palit ng spark plugs (copper Denso K20HR-U11), air filter PLUS the 5Kms PMS.
Every 40Kms palit din lahat ng oil (engine, transmission, differential, power steering) pati coolant at brake/clutch fluid. Palit din lahat ng filters.
Thanks po
March 11th, 2009 09:26 AM #9605
Sir MILE2 Maraming Salamat
40K lang po yung ODO ko. i will do what you said.
Last question lang po..pag-iniistart ko yung innova biglang nag re-rev ng hanggang 3k rpm pero hindi naman ako tumatapak sa accelerator at yung idling niya ay 1.5k pero after few minutes babalik na yung idling below 1k. ganun po ba talaga yun?
Maraming salamat, sobrang dami kong natututunan na thread na to!
- Aug 2008
- 164
March 11th, 2009 02:05 PM #9606Hi to all tsikoters, mag inquire lang po ako kung saan magandang bumili ng accessories ng innova particularly yung (rear spoiler and body moulding) kasi masyadong mahal sa casa. I went minsan sa banawe and i did inquire sa Goldrich ok naman offer nila, i jus want to have other options on where else i can buy at reasonable price and ok din ang service. salamat po!
March 11th, 2009 06:30 PM #9608
At 40K dapat palit na lahat ng fluids ng auto especially yung transmission and differential, kahit mukhang malinis pa yung transmission oil pero marami na rin yang minute solid particles, nakita ko yan ng mag 40K PMS ako dahil pinakita sa aking mechanic kung gaano kakapal ang residue sa drain plug.
Normal lang na mataas ang idling after cold start, kusang bababa ang idling after few minutes when it attain certain temperature and pressure. Nothing to worry
March 12th, 2009 10:39 AM #9609
mile2,
i've noticed sa sig mo na you're using denso iridium plugs, maganda ba performance nito? and is the plug colder than stock? i have the G vvti a/t variant pala. plano ko kasi magpalit ng colder plug since yung innova ko tumotope paminsan minsan pag nagkarga ako ng petron xtra unleaded or xcs, sa blaze lang hindi tumotope kaso ang mahal naman ng blaze. replaced my plugs twice na, even the fuel filter, pati lahat ng sensors pina check ko narin pero ok naman.last resort ko nun is i had my fuel injectors cleaned and got the tank flushed and filled with blaze, dun lang tumino. pero nag try uli ako once sa xcs and bumalik yung tope. mapili ba talaga sa gas ang innova?
March 12th, 2009 01:42 PM #9610
LPG fuel is the main reason I go for 1 step colder Iridium, it is for longer spark plug life. I have also tried Iridium IKH20 same heat range of the stock copper K20HR-U11 and performance is the same.
Di naman mapili ang Innova 2.0 1TRFE engine sa types of unleaded, I'm using E10 (+2 years na) and LPG (8 months) pero so far okay naman ang performance.
Kung tope yan, baka di na yan sa fuel kundi sa carbon deposits, try mo ihataw paminsan minsan para lumipad lahat ng carbon pati na yung nasa catalytic converter. My everyday route is lots of traffic and some long freeway stretch kaya panay ang hataw minsan. Pumipino ang idling ko pag naihahataw ko.
I forgot, ginalaw ba ng mechanic mo yung mga rubber boots ng Stick Coil? baka kasi mis-aligned yung spring sa loob. Also make sure you have the correct spark plug gap and no mis-aligned spark plug ground tip.Last edited by Mile2; March 12th, 2009 at 01:45 PM.
Out of sight, out of mind! :grin: Seriously though oil pressure was addressed in the video, both...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
