Page 635 of 662 FirstFirst ... 535585625631632633634635636637638639645 ... LastLast
Results 12,681 to 12,700 of 13229
    #12681
    yes, ganyan din ako. it has turned me into an honest man. hindi na ako kumukuha ng pirate. all originals na po!
    sakin ok naman... kahit na anong pirated na cd's nag play naman ng mahusay... 2years old na innova ko...
    tiempo tiempo lang siguro..
    di ko pa nagagamit sa orig cd yun...
    Apr 2010
    #12682
    Mga Sir,
    I recently purchased an Innova J and balak ko sanang lagyan ng spoiler w/ 3rd brake light ok lang ba sa labas ko pagawa? Advice kasi sakin ng agent ko is sa toyota na lang ipagawa baka ma void yung warranty kung sa labas?Thanks
    May 2010
    #12683
    your 6km/l depends on your driving style, tire pressure. and the stuffs you put in you car. baka mabibigat yung dala mo.
    dont put additives. bago pa yung ride eh
    Feb 2009
    #12684
    hi guys may i ask whats the main difference between innova G and V?
    thanks in advance!
    Dec 2009
    #12685
    Quote Originally Posted by shibby75 View Post
    sakin nov 2009 ko kinuha, meron filter. sa case ng error mp3, try mo mag burn ng cd at a lower speed tapos check mo yung box na verify data. I use burned mp3 on any cd brands. ok naman sa akin.
    Ok, thanks po sir shibby. gawin ko po advice mo.
    Quote Originally Posted by montcp View Post
    Sa pagbuburn try to use the lowest speed, im sure magwowork na yan.
    Thanks po Ginawa ko na po sa settings na "minimum". naka-set kasi pala sa automatic.
    Quote Originally Posted by kurtsm View Post
    Tama yun suggestion nila... pero pag hindi pa din nagwork, yung player na ang may problem (namimili ng CD)... meron kasing ganyang mga player na sobrang sensitive - mostly ng binabasa nya original at minsan nga hindi pa rin binabasa.
    Isa pang work around solution is to clean the player. may nabibiling cleaner nyan sa mga CD store.
    Hope nakatulong.
    Thanks thanks! yup, sensitive nga siya. actually hindi pa nakaktikim ng original CD yung innovanessa ko
    Thanks for all the quick reply sa question ko mga ka-iinnova.
    Mga ka-innova, share niyo naman yung mga tawag niyo sa innova niyo. Share their names para masaya. Mine is '07 Innova J M/T. Her name is "Innovannesa"
    Oct 2009
    #12686
    Quote Originally Posted by pat_louie View Post
    Bagong topic yan...
    My Innova name is "Inno".
    #12687
    I call my innova "INNOVAtion"
    #12688
    guyz tanong ko lang:
    what kind of suspension is our Innova using; shock or bolye (dunno if this is the term what you call on the straight bar that serve as a suspension)?
    Front?
    Rear?
    does our innova has already an equipped rear stabilizer from the moment we purchase it from the casa? if not, what is that straight bar on the rear side below our Innova? it almost looks like a rear stabilizer, but am not sure on that...
    Jun 2006
    #12689
    i think your referring to a torsion bar. Gamt yon instead of spriings. Harap ng Fx ganon.
    Wala ata rear stabilizer ang innova kasi live axle sya. Yung anti sway bar ang hanap ko, para mabawasan ang sayaw ng pwit sa biglang liko...
    or molye or leaf spring? la tayo nun, adventure, crosswind meron nun.
    #12690
    ganun ba; torsion bar tawag sa innova? what is that yan ba yun parang shock absorber ng innova?
    bolye or molye yata yun naka-kabit sa ibang SUV; yan yun parang bakal na naka-kabit sa karamihan sa jeepney that serve as suspension
    Jun 2009
    #12691
    dearest tsikoteers penge lang advise kung ok bilhin yung innova ng friend ko..2005 G variant gas manual beige, pwede na ba yun sa 550k? Sariwa naman walang papagawa.First owner sya 65k mileage,balak nyang magpalit ng xwind xuvi na brand new kaya dispose nya to..Ano sa palagay nyo ok na ba ang price? sagad na raw kasi eh..
    Aug 2006
    #12692
    Quote Originally Posted by Louga View Post
    hello po.
    may question lng po ako about sa aircon filter ng innova 2009 ko. kc lilinisan ko sna kanina un filter don sa ilalim ng lower glove cabinet pro non biniksan ko ay wlang syang laman. naopen ko un cover ng maliit ng box sa loob pro to my surprise wlang laman. nafollow ko nmn un instruction sa manual.
    tumawag ako sa toyota bicutan about sa filter and sbi optional dw un at dpat bilhin ko kng gus2 ko magpalagay. based sa nabasa ko d2 sa forum merong filter ang 2007 up model and nkakapaglinis cla.and nagtaka din ako kc ang aircon ay laging may filter.
    salamat po.
    Tama po, 2007 model with honeycomb grills and later facelifted 2009 model dapat meron ng cabin filter. Standard na po yan sa later models.
    Puede kayong mgareklamo sa dealer nyo, huwag sa SA dahil minsan yan mga SA di nila kabisado specs ng mga products nila. Talk to Customer Relation Officer (CRO), lahat ng Toyota dealer merong CRO.
    Aug 2006
    #12693
    Quote Originally Posted by neilbino View Post
    Actual unit cost niya noon 2005 ay P940K. Puede na yan sa P550K.
    Malamang stock pa ang gulong niyan kaya palitin na, mga P3,400 per tire ang bago.
    Check for leaky shocks, engine oil leaks and radiator. In as much as VVTi is concern, matibay naman at worry free but to make sure you are buying a car with minimal repairs better have it lifted at a nearby gasoline station to check the undercarriage parts.
    Addtional: Check if it has the 40K PMS, at 40K PMS all fluids (radiator, transmission, differential, power steering, brakes) are replaced. Check also history of brake pads replacement if already done.
    May 2010
    #12694
    Quote Originally Posted by Mile2 View Post
    samalat po. tawagan ko ngyn toyota bicutan ulit.
    #12695
    ok na yan price na yan for an Innova G variant
    just check on the wear and tear of the exterior and interior parts of the car
    #12696
    Dec 2009
    #12697
    Quote Originally Posted by ajOT View Post
    Cool, i saw you're thread ng innovation mo boss. astig!
    Bagong topic yan...
    :cheers2:
    Check Alamin din po kung ondoy victim
    #12698
    what kind of suspension is a Toyota Innova using?
    shock absorber? trailing arm?
    when do we usually replace it; standard way to replace it?
    coz I dont want to wait for it to be worn out before I replace it; safety first.
    #12699
    :cheers2:
    tnx for appreciating the INNOVAtion
    * neil - yah id agree check if it was submerged on any flood, typhoon, etc. especially Ondoy (2009); Milenyo (2006), and others....
    Dec 2007
    #12700
    Quote Originally Posted by superbismarck View Post
    Hi, also got a D4Dmt , never ako naka 10.5km/l average ko lang is 7.++ sa city driving. should i improve on driving or kasi puro turns ang dinadaan ko. eskinita, from Manila to makati. daily used.
    Kung napapako ka nang husto sa traffic eh it should make sense kung bakit mababa ang FC mo. Kung puro turns pero derederetso naman, it should not be that low. Parati bang may pasehero ka or mabigat na kargada? Yung officemate ko AT pero parehas kami ng consumption
    Quote Originally Posted by Blackshark1999 View Post
    Yes FC 11.5km/l is pure city driving. My innova is Model E D4D MT year 2008. I'm from Tondo and I work at Makati.
    Wow, ganda ng FC mo talaga. If I'm correct yung way mo e medyo matraffic. Pareho tayo ng model although I acquired my unit Nov. of 2007.
Toyota Innova Owners & Discussions [ARCHIVED]
