Results 401 to 410 of 560
- Mar 2010
- 15
June 2nd, 2013 03:18 PM #401All done.
Will post photos later for reference.
Changes made by Toyota to the designs
1. Filler cap. The new filler cap does not have the filter mesh anymore. Also, it is easier to separate from the black housing.
And the filter cap was really designed to let air in easily. I tested it by sucking/blowing on the cap. but it is hard for the air to go out. i think it really designed this way so the evaporated gasoline cant easily get out but it will be easy to let air in.
2. the new tank has a flange mount on where the tubes are connected.
BANNED BANNED BANNED
- Feb 2013
- 487
- Mar 2010
- 15
June 2nd, 2013 03:36 PM #403Yeah, bought all 3 na eh.
So ang magandang gawin pala, alisin lang yung filter mesh sa lumang filler cap, ok na. tutal inalis naman ng Toyota yung mesh sa bago nilang filler cap.
- Feb 2013
- 487
June 2nd, 2013 05:46 PM #404Iba na ba yung itsura ng bago na filler cap?
How much po yung breakdown? Thanks.
- Mar 2010
- 15
June 2nd, 2013 10:57 PM #405I got everything from Toyorama. Best Sunday magpickup, kasi open din sila 9 to 12nn.
Filler Cap - 1450
Charcoal Canister - 8080
Tank - 14670
Anyway, nung sinubukan ko hipan ang charcoal canister, medyo mas mahirap ng kaunti lang hipan yung luma compared sa bago. So I guess yung main culprit talaga dito is yung filler cap na barado.
*** Remove the filter mesh now ***
Anyway, here are the photos
Old Filler Cap
Filler cap housing removed. Dirty filter mesh shown.
Dirty mesh and Cleaned Mesh
New cap
New Cap has no mesh. Guess the new design does not need it...or they found the cause of the negative pressure.
June 2nd, 2013 11:13 PM #406
Even with the dirty mesh bro, I wouldn't think it can hold or push that pressure.....
- Mar 2010
- 15
June 2nd, 2013 11:19 PM #407
Tanks side by side. right one is the new tank. Floater assembly already moved to the new one.
Check out the difference. New tank has flange connection on the ports. Siguro may nasisira din na welds kaya ginawa na lang nilang replaceable.
Leaky tank and a close up. Tank oriented upwards. Upwards is towards the front of the car.
*The strap that holds the tank up is covered with rubber sheet. So the leak was really due to the repeated stress the metal undergoes because of the repeated deflation and inflation of the tank due to the negative pressure. The direction of the hole is even towards inside the tank.
- Mar 2010
- 15
June 2nd, 2013 11:26 PM #408
- Feb 2013
- 487
June 2nd, 2013 11:29 PM #409Mapag ipunan na nga yang ganyang cap..
Yan nga yung bago, based sa ToyoDIY.
New filler cap. 77300-52030 (08/2008 - )
Old filler cap. 77300-28010 (08/2004 - )
- Feb 2013
- 487
June 2nd, 2013 11:38 PM #410
Balikan ko lang itong mga gumugulo sa isip ko kaya na-pa-reply ako sa thread na ito... was...
China cars
