Results 301 to 310 of 559
July 27th, 2012 03:40 PM #301
July 27th, 2012 04:18 PM #302
- Jun 2012
- 44
July 28th, 2012 05:09 AM #303
July 28th, 2012 08:30 PM #304
Just Sharing my experience today....
i saw my gas tank warp kanina after driving to the mall... Tama si Sir Mile parang sinuntok and i panic... i open the fuel cap and wooooooooooooooeeessss i heard the air going in to my gas tank... after that i saw my gas tank back to normal. After that di ko sinarado maayos ang fuel caps para di mag warp ulit ang tank ko.
i usually heard fast tiktik sound at my charcoal canister after driving.... and now nong di ko sinarado maayos ang fuel cap... i heard no tiktik sound anymore at my charcoal canister....
is it the fuel cap had a problem or the charcoal canister? gas tank can't get air from outside?
how does a fuel cap works?
July 29th, 2012 11:14 PM #305
Wow,- mukhang nagiging vacuum ang loob ng gas tank... Kasi, the normal experience with gasoline vehicles nowadays is you hear air coming out of the gas tank. This is my experience with our Innova and our 09 Honda car...
Would it help if you close your fuel cap with just one click, as suggested by the manual, Sis? Or, are you doing that already?
16.4K:bond:
July 29th, 2012 11:41 PM #306
I did the one click as suggested by the manual... i'm the one closing the fuel cap pag nag pa gas ako.
i think the manual is wrong... dapat ilagay nila doon "NO CLICK". at yun ang ginagawa ko as of now.
Biglaan ang pag warp ng gas tank ko Sir CVT... last month nag pa align me, change oil etc... sunod sunod na araw araw ang pag check ko sa gas tank... and no sign of warping. last 5 days ago medyo may nakita akong konting dent malapit sa belt ng gas tank at yun na ang sign. Kung 2005 model ng Innova mo Sir i think dapat palitan mo na kahit fuel cap lang muna. I think it took 1 day of full driving, mabubutas na gas tank mo.
ito ang problema ko ngayon... i'm in the province at no choice ako sa CASA lang ang meron nito.
Pa request naman Sir Nic Picture sa OLD Fuel Cap at yung New Fuel Cap mo...at the breather hole...
Try ko muna i order ang Caps muna then i will observed...
July 30th, 2012 09:27 AM #307
Filler Cap is cleanable and can be restored, you'll just need to use 2 small screwdrivers to skewed the snap in top and bottom caps and inside is the breather hole mesh filter. I can't remember if the filter mesh was Plastic or Stainless Steel but it should be around #100-200 filtration holes. If the filter mesh is filled with soot like dirt then it is one of the cause of negative vacuum on the gas tank.
July 30th, 2012 09:48 AM #308
July 30th, 2012 09:50 AM #309
July 30th, 2012 11:18 AM #310
Yepp. Hit or miss talaga Chinese-English translations.
Amaron battery
