Page 39 of 56 FirstFirst ... 2935363738394041424349 ... LastLast
Results 381 to 390 of 559
    Oct 2011
    #381
    Ung gas tank woes ng earlier innova, isolated cases lang ba ito? or majority na apektuhan nito.
    #382
    is it accurate to say, that only gas variants had this problem and not diesels?
    and, i also got the impression that, just like the D4D fuel feed problems, they were the clear minority...?
    #383
    Yes. It seems like that, bro.
    18.4K:sun:
    #384
    Quote Originally Posted by kristine123 View Post
    wala ng problema sa mga bagong labas. kahit 2005 kong Innova wala na ring problema dito
    boss just like to check i have 2005 innova but whenever i open the gas cap malakas ung vacuum is this normal?
    Aug 2006
    #385
    Quote Originally Posted by rickb888 View Post
    That's normal, this condition was mentioned in your Owner's Manual for your reference.
    #386
    just check from time to time kung nag deformed ba ang gas tank mo.... in case na deformed, hindi na normal.
    Oct 2011
    #387
    yes, gas tank woes is vvti only. iba naman sakit ng d4-d sir.
    #388
    Count me in.
    After inspection of the tank, I can see mine also warped. It cannot be "something that hit the tank" since the strap that holds the tank was not warped; definitely negative pressure. Will be reading through this whole thread to find the solution.
    Feb 2013
    #389
    Specs ng Innova mo?
    #390
    Quote Originally Posted by jepps137 View Post
    Count me in.
    hanap ka solution before it's to late...mas lalaki ang gastos mo pag mabutas ang gas tank...
Toyota Innova Gas Tank woes
