Results 5,391 to 5,400 of 5535
- Dec 2019
- 2,073
May 8th, 2021 11:15 AM #5391price difference only by the name casted on the water pump. In the end it's the same part that was manufactured by Aisin.
May 8th, 2021 12:41 PM #5392
Or Maybe it’s not the water pump this time? [emoji2373] I just went to another trusted mechanic, he noticed that the auxiliary fan is really wobbly, mahina na daw motor. He said the (bird chirping) sound is not coming from the water pump side. He also said palitin na serpentine belt kaya umiiyak.
- 54,211
May 8th, 2021 07:19 PM #5393chirping sound?
in my car, that would be the idler pulley. does this car have an idler pulley?
i can make the birds disappear for 2 weeks with a squirt of lubricant, but it's sure to return.
the permanent fix is replacement.
wobbly aux fan?
try tightening the turnilyos first.
but i have a question to the post-er.
how did you conclude that the water pump needed replacing?
May 8th, 2021 09:30 PM #5394
It was based on previous experience doc. Twice na napalitan water pump with same symptoms.
- 54,211
May 8th, 2021 10:00 PM #5396
May 14th, 2021 07:03 PM #5397
Share lang, did my 70k service awhile ago at Toyota Marikina. Nung rinequest ko sa Service Advisor, rinecommend niya na sa 100k na gawin, usually ganoong mileage daw nagrereplace ng cvt fluid sa kanila. Medyo pinush ko pa rin and pumayag din naman. Cost for the CVT fluid change is around 750-labor, 2230-CVT FE 4L, total 3k + oil change costs. Rinequest ko actually na makita sana yung tinanggal nila na fluid, pero nalimutan siguro itabi or something nung mekaniko. Pero cinomment ni SA na maitim daw yung nakita nilang fluid, so I guess good thing na napalitan na. Hopefully walang biglaang i-reveal na damage sa CVT yung change
May 16th, 2021 09:06 AM #5398
May recommended shop ba for CVT fluid oil change?
May 16th, 2021 10:23 AM #5399
May 16th, 2021 10:51 AM #5400
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
