Page 526 of 554 FirstFirst ... 426476516522523524525526527528529530536 ... LastLast
Results 5,251 to 5,260 of 5535
    Jul 2018
    #5251
    Quote Originally Posted by Kath_Tzikot View Post
    Mga boss, anong recommended nyo ng brand ng tires? Thanks!
    Will be use for:
    -daily driven
    -ok ang grip during wet season
    -laguna to alabang/mckinley daily
    Bridgestone Potenza RE003
    Oct 2018
    #5252
    Quote Originally Posted by MaiGaspan View Post
    thanks bossing!
    Feb 2014
    #5253
    Help lang po. Im not sure if this is the proper forum to ask for help - here is my problem
    I have a 2011 Altis. its all good. but recently, i noticed that the car vibrates while on drive and when the car is stopped (not moving). The vibration feels like the engine is about to give out (turn-off) - sounds like choking. I also noticed that that there is low power in low speeds climbs - i.e. difficulty in climbing steep roads.
    I just had the spark plugs checked and cleaned and the tube where the air passes through going to the engine (not sure what it is called). The vibration has been reduced but the low power in climbs issue is still there.
    any ideas?
    TIA
    Quote Originally Posted by black0men007 View Post
    any ideas?
    TIA
    4 things that makes the engine work.
    ecu
    air
    fuel
    spark
    check ecu for codes..
    coil packs?
    fuel filter perhaps?
    Feb 2014
    #5255
    ecu
    air
    fuel
    spark
    coil packs?
    Sir, since the spark and air have been checked, it only leaves the ecu and fuel filter? how do we check for the ecu codes? can that be done on the vehicle or do i need a special device for reading the ecu codes?
    Should i have the fuel filter changed also to rule it out? anyway have never changed the fuel filter since i bought the car in 2011, maybe its due for a change na?
    for ecu codes you need a mechanic/shop that knows that engine.. he can see the sensor readouts like O2 and MAF ..coolant temperature..
    air also includes compression but i think that engine is quite reliable.
    spark.. defective coil pack symptoms: loss in power and vibration.
    imo fuel filters doesnt last 8years. so maybe start there.
    Feb 2014
    #5257
    thanks. Will have the fuel filter changed next. spark plugs are still okay as per mechanic. he just cleaned them. if that fails will have take to a shop that can read the ecu codes
    BTW, any recommendations for a good shop or mechanic in the south or around mandaluyong are? i usually have work on my altis done by mechanics at gas stations (change oil etc).
    #5258
    good afternoon!
    question lang po regarding sa aircon ng toyota altis 2015.
    ano po ba ang dapat palitan kapag ayaw magsara ng vent for circulation mode? tiningnan ko po kasi under the dashboard kaya pumapasok yung hangin galing sa labas dahil ayaw mag total sarado yung vent.
    thank you and have a great day!
    Apr 2005
    #5259
    My car is running 140K km next month. Ano ba ginagawa kapag preventive maintenance at that mileage?
    Dec 2007
    #5260
    Who here skipped the fuel filter replacement on their 40K km PMS? I’m thinking of extending the change interval to 50K or even 60K km. A little pricey at 6K plus. 99% of the time, doon lang ako sa suki kong shell station nagpapakarga.
Toyota Corolla 11th Generation Altis [Merged Threads]
