Page 298 of 358 FirstFirst ... 198248288294295296297298299300301302308348 ... LastLast
Results 2,971 to 2,980 of 3575
    Jun 2012
    #2971
    Quote Originally Posted by _incubus19 View Post
    Hi, hindi ko alam kung tama un ginawa ko pero hindi ako makastart ng new message. Kaya pinili ko un reply with quote tapos dinelete ko un quote.
    I just bought a 2011 1.6g A/T. I think I need to change the tires. In front, the manufactured year is 2013 while rear is 2011. I read that Ben’s Ok is good tire shop. Problem, anong brand and tire size un recommended sa altis? Ayaw ko ng china brand. Target price ko is below 4k per tire. Any suggestions?
    Sorry po kung mali un style ko ng pag reply. Hindi ko alam paano mag start ng new message. Safari browser ang gamit ko. Thank you.
    Good pa ang 4 yr old tire ah? Kalbo na ba?
    Sent from my SM-A9000 using Tapatalk
    Apr 2005
    #2972
    My stock mags is size 15s. I have an idea regarding sa manufactured date ng tires. I just don’t have an idea what are good and reliable brands. Un bridgestone hindi ba mahal un?
    I am currently using Bridgestone Ecopia 16s worth 4.4K each. Sa Minerva Tyre Gallery ka bumili. Okay dun. Kumho tires are also good, mas mura pa. Kung talagang kulang sa budget, 2 tires muna ang bilhin. Sa harap ilagay ung brand new.
    #2973
    My stock mags size is 15s. What should be the appropriate tire dimension? 205/60/15? Thanks
    factory spec po. baka kasi ma-throw-off ang speedo and odo.
    baka nasa owner's manual ang size.
    Jun 2014
    #2974
    Quote Originally Posted by dct View Post
    Ok pa naman un 2 front tires. Makapal pa. Pero double check ko. But the 2 rear tires need to be changed. It is 2011 and i think nasa 70% thread pa.
    Assuming the 2 front tires are still ok, should I buy the same tire dimension of the old tires? what should be the pattern of the new tires? Will I be putting it on front or rear?
    Jun 2014
    #2975
    Nakita ko sa s&r merun sila kumho tire. 3.3k pero hindi ko sure kung same dimension ng current tire ko. Kaso may mga additional fees pa ata sa s&r like installation, nitrogen etc. Nasagot mo na pala un question ko sa kung saan ilalagay un 2 new tires. Thanks!
    Jun 2014
    #2976
    Sorry for I have many questions. Un nabili ko na 2nd hand altis does not have casa maintainance records and I bought on buy and sell. So I need to have it change oil, oil filter and check all the necessary parts to be checked. With regards to change oil, san ok magpagawa or where to buy oil and oil filter? Un vios ko dati ginagamit ko ZIC oil and baldwin filter.
    Also, may “tok” sound un steering wheel ko kapag ginagalaw ko pa right. Kahit pa left merun din pero mas malakas un pa right.
    Nag back read ako ang sabi either rack & pinion, cv joint, ball joint or shock absorber. Saan din ok magpacheck? Sana po along QC. Sa fairview kasi ako nakatira. Thank you in advance.
    #2977
    Buying tires in S&R already includes everything - installation, balancing, wheel weights, and nitrogen. With free refill for the life of the tire. Sometimes they have a promo of buy 3 take 1 free, I've availed of this twice already.
    Jun 2012
    #2978
    Gano ba katagal ang dapat na palit ng tires kahit makapal pa? Some says 6 yrs. Some says 10 yrs. Ano ba talaga?
    #2979
    when my car's warranty ran out, i started changing oil w/ filter, at the gas station. the petron i go to, has an hecho derecho promo that includes the oil and the oil filter. pasok naman sa spec ang oil nila. less than 1.5K lahat-lahat, and i am done in under an hour. i do not use flush, engine or oil treatment, and even air. just gravity drain.
    that "tok" sounds like CV joint. $$$!
    Jun 2014
    #2980
    Quote Originally Posted by loverlionus View Post
    Sakto magkakaroon ng sale ang s&r from sept 27 to oct 1. Baka may promo din sa gulong. Problema sobrang haba nanaman ng pila. So the price of the tire that I saw (kumho) worth 3.3k, that’s all i’m going to pay? May nakalagay kasi sa labas na fees. Baka siguro ineexplain lang nya un price pero free na sya. Sana meron promo na buy 3 get 1 para palitan ko na lahat ng tire. Salamat sir!
Toyota Corolla 10th Generation Altis Owners [continued]
