Results 2,971 to 2,980 of 3568
- Jun 2012
- 4,448
September 22nd, 2017 08:41 AM #2971
September 22nd, 2017 08:47 AM #2972
- 52,700
September 22nd, 2017 08:52 AM #2973
September 22nd, 2017 10:44 AM #2974
Ok pa naman un 2 front tires. Makapal pa. Pero double check ko. But the 2 rear tires need to be changed. It is 2011 and i think nasa 70% thread pa.
Assuming the 2 front tires are still ok, should I buy the same tire dimension of the old tires? what should be the pattern of the new tires? Will I be putting it on front or rear?
September 22nd, 2017 10:49 AM #2975
September 22nd, 2017 10:54 AM #2976
Sorry for I have many questions. Un nabili ko na 2nd hand altis does not have casa maintainance records and I bought on buy and sell. So I need to have it change oil, oil filter and check all the necessary parts to be checked. With regards to change oil, san ok magpagawa or where to buy oil and oil filter? Un vios ko dati ginagamit ko ZIC oil and baldwin filter.
Also, may “tok” sound un steering wheel ko kapag ginagalaw ko pa right. Kahit pa left merun din pero mas malakas un pa right.
Nag back read ako ang sabi either rack & pinion, cv joint, ball joint or shock absorber. Saan din ok magpacheck? Sana po along QC. Sa fairview kasi ako nakatira. Thank you in advance.
- Oct 2006
- 261
September 22nd, 2017 10:59 AM #2977
- Jun 2012
- 4,448
September 22nd, 2017 11:28 AM #2978Gano ba katagal ang dapat na palit ng tires kahit makapal pa? Some says 6 yrs. Some says 10 yrs. Ano ba talaga?
Sent from my SM-A9000 using Tapatalk
- 52,700
September 22nd, 2017 11:41 AM #2979when my car's warranty ran out, i started changing oil w/ filter, at the gas station. the petron i go to, has an hecho derecho promo that includes the oil and the oil filter. pasok naman sa spec ang oil nila. less than 1.5K lahat-lahat, and i am done in under an hour. i do not use flush, engine or oil treatment, and even air. just gravity drain.
that "tok" sounds like CV joint. $$$!
September 22nd, 2017 01:47 PM #2980
Sakto magkakaroon ng sale ang s&r from sept 27 to oct 1. Baka may promo din sa gulong. Problema sobrang haba nanaman ng pila. So the price of the tire that I saw (kumho) worth 3.3k, that’s all i’m going to pay? May nakalagay kasi sa labas na fees. Baka siguro ineexplain lang nya un price pero free na sya. Sana meron promo na buy 3 get 1 para palitan ko na lahat ng tire. Salamat sir!
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
