Page 142 of 163 FirstFirst ... 4292132138139140141142143144145146152 ... LastLast
Results 1,411 to 1,420 of 1628
    Jul 2010
    #1411
    Kahit may catchcan ka pa.. Oil will always be present in your intake manifold.. As long as you connect the crankcase ventilation in the intake, there will always be oil.
    Afaik, oil in the intake provides lubrication in the turbo's impeller/blade.
    If you want no oil, either you dump the blow-by gasses in the atmosphere or you install a water/meth injection.
    Apr 2012
    #1412
    Quote Originally Posted by BRIAN View Post
    mga sir ask ko lang meron ba problem sa 3.0 fortuner na yun turbo nag kaka oil?
    pumunta kasi ako sa isang talyer kanina, dami na daw nila ginawa ganun case sa fortuner.
    since fortuner kasi dala ko kanina na tanong lang ng mechanic sa akin
    Sir Brian,
    Ung 2012 Innova J D4D ko, napansin ko din na nagkaka-oil sa turbo. Pina check ko sa CASA during my 5K PMS. Sabi nila normal lang daw un. Ibalik ko na lang daw sa kanila pag umulit ng ganun.
    Pinunasan nila sa casa para matuyo ung labas pero paguwi ko, tinanggal ko ung intake hose at nakita ko na medyo madami ngang oil sa loob. Pinunasan ko na din. Up to now, ok pa naman takbo ng Innova ko
    Oct 2011
    #1413
    Normal lang un, minsan pa ata pati sa air filter napupunta ung oil.
    Feb 2013
    #1414
    Paano nagging normal yan?
    Jul 2003
    #1415
    Quote Originally Posted by siopaonatoasted View Post
    If I am not mistaken, turbos are oiled for lubrication and cooling.
    Oct 2011
    #1416
    Correct. Wag lang ung maraming langis. Usually parang nag momoist mapapansin mo dun.
    Feb 2013
    #1417
    Turbo must be oiled pero kung yung air intake ang may oil, mukhang iba yan.
    May 2013
    #1418
    Good morning mga sirs. Re-post ko lang dito.
    May mga tanong ako about what happened to my father in law's fortuner.
    1. May thick white smoke na lumalabas pagka start specially in the morning though nawawala after 30 mins or so. Ano kailangan kong patingnan?
    2. May leak sa fuel injector pump, saan ko pwedeng dalhin para ipagawa?
    3. Saan pwede magpagawa ng remote-key? Sira na pati pindutan.
    Salamat!
    Feb 2013
    #1419
    Quote Originally Posted by micainna View Post
    Salamat!
    Ang alam ko kapag may thick white smoke, marami yan factors, pwede may valve seal leak ka, pwede rin nagsusunog ng coolant. Check mo coolant levels mo.
    Dalhin mo sa casa.
    May 2013
    #1420
    Thanks sir siopaonatoasted.
    Sir do you know any trusted mechanic in qc other than the casa?
    Thanks again.
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
