Results 1,391 to 1,400 of 1628
February 12th, 2013 10:05 PM #1391
February 13th, 2013 06:03 PM #1392
Is there a "fuel-water separator" installed in a Fortuner D-4D engines?
February 14th, 2013 12:12 PM #1393
February 14th, 2013 12:21 PM #1394
yep, may pang pump doon sa taas ng housing that lets you pump water out just in case water gets through.
February 14th, 2013 09:09 PM #1395
On the innova, as will probably be the case with the fort, the priming pump and fuel filter is in one housing assembly. The priming pump does not allow you to pump water out, it is used to "prime" the fuel system. The assembly performs some sort of separation because of the housing itself, as water is heavier than diesel fuel, it tends to settle below the fuel, you then use the drain plug to let water out, manually. Fuel water separators usually have transparent bowls that let's you visually inspect for water accumulation. In innova, detections comes automatically and you will be notified through the dashboard notification. You then open the drain plug to let water out.
February 16th, 2013 12:33 PM #1396
BANNED BANNED BANNED
- Feb 2013
- 487
April 21st, 2013 12:01 AM #1397Hmmm... Mukhang magkakaroon ako ng D4D hehehe... May gusto makipagswap sa VVTI ko, dagdag lang daw ako ng 100k..
- Feb 2013
- 487
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
