Results 1 to 7 of 7
June 22nd, 2011 12:01 AM #1
mga sir.ngbbyahe ako gabi. naka bright yung headlight ko.then bigla nalang nawala ilaw ko!
recently nagpalit ako ng bulb, super white na 90/100watts. naglagay din ako ng relay.
last2 week lang nilagay yun.tapos ngayon bigla nawala ilaw ko.
ano kaya problem nito?idea lng sir. para baka ang may kasalanan eh yung ngkabit. tsk!
June 22nd, 2011 01:05 AM #2
June 22nd, 2011 12:18 PM #4
June 22nd, 2011 01:26 PM #5
June 22nd, 2011 05:02 PM #6
June 23rd, 2011 09:48 AM #7
IMO, parang mali to just up the fuse amperage. Normally we just use 10 or 15amps on our headlights/foglamps and they work well. I think the problem is more with the install and upgrade made (cheap relay? wrong wiring?). Check also your sockets if they are melted.
If im not mistaken, this was already discussed by the TS some weeks back (upgrading headlamps) and i recall most of the posters advised not to cheap out on the upgrade and do it properly to avoid problems.
If you think about it, if the price of the battery does not go down, replacing the battery of a...
Mitsubishi Xforce
