Results 1 to 8 of 8
- Jun 2011
- 4
June 12th, 2011 05:17 PM #1gud pm tanong ko lang po kung san ako pwede ako makabili ng timing belt and oil seal for my corolla 95 model engine 4A-FE. meron po ba nito sa any toyota branch and magkano po kaya? saka pati yung brake master kit ?
- May 2004
- 903
June 12th, 2011 05:20 PM #2Go to banawe sir... dami dun.. I prefer toyocars or toyorama.... Dun ako bumibili ng mga parts ko for toyota....
- Jun 2011
- 4
June 12th, 2011 05:25 PM #3meron din po ba na magaling na auto repair shop malapit dun kasi po balak ko n dun na rin po magpagawa ng auto regarding sa brake problem yun maayos na shop po
June 12th, 2011 06:42 PM #4
Go to Ichiban in Banawe, a few meters away from E. Rod, left side. Hanapin mo si Atong o kaya si Teddy
June 13th, 2011 03:28 PM #5
x2 with the shops the guys mentioned above. I usually go to Toyorama or NGK depending on what parts i need and for what car. NGK usually has parts available for older models which are hard to find.
Toyorama: 712-0016, 731-9999
You can also call or go to the nearest Toyota CASA to canvass parts for comparison.
HTH.
- Jun 2011
- 4
June 14th, 2011 02:36 AM #7
marami nagkalat na shop sa banawe na meron mga aftermarkets na timing belt at oil seals. mura din ito. pero kung ako tatanungin go for the original parts pagdating sa mga belts. goodluck
- 18
June 22nd, 2011 01:45 PM #8For your comparison recently bought some orig toyota parts at casa ( gli 2000)
timing belt 1,324.06
oil seal P323.45
oil seal P 254.70
-after 10% discount yan using Toyota mastercard-
pero tensioner bearing replacement KOYO brand lang ginamit ko P 600 compared to P 4,013 OEM casa price.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
