Results 1 to 7 of 7
    mga sir.ngbbyahe ako gabi. naka bright yung headlight ko.then bigla nalang nawala ilaw ko!
    recently nagpalit ako ng bulb, super white na 90/100watts. naglagay din ako ng relay.
    last2 week lang nilagay yun.tapos ngayon bigla nawala ilaw ko.
    ano kaya problem nito?idea lng sir. para baka ang may kasalanan eh yung ngkabit. tsk!
    Quote Originally Posted by j_dipad View Post
    Check the wiring. Also check the relay, it could have burned out if it was a cheap relay.
    May 2011
    Check the fuse if both lights went out.
    Quote Originally Posted by rattrapante View Post
    got it sir.busted fuse nga ng relay.mababa yung fuse.25 lng daw.dapat daw nsa 30 na fuse,o pinalitan ng 30. ok na b yun sir?
    Feb 2005
    I thought so too. Good it's just the fuse.
    An added reminder, do not use higher than recommended fuse amperage. Baka matunaw (or masunog) wiring mo.
    Quote Originally Posted by Benzmizer View Post
    30amp na fuse ok na ba sir?nka 90/100watts ako na relay and bulb.ano recommended na amp ng fuse?thanks
headlight suddenly turned off!
