Page 128 of 138 FirstFirst ... 2878118124125126127128129130131132 ... LastLast
Results 1,271 to 1,280 of 1371
    Apr 2010
    #1271
    no refacing yet bro. I just told by the manager to do the refacing when i replace my pads para d din sayang.
    #1272
    Quote Originally Posted by n0cary3t View Post
    if i see that judder as unsafe or distracting, i wouldn't wait and i'd have it fixed asap.
    there's no telling, what branch might grow from it...
    Jun 2005
    #1273
    Quote Originally Posted by Joe Magarac View Post
    How much did you spend for the re-facing n0cary3t? Just asking so I can prepare for the budget.
    Your suking talyer will probably charge you 2500 and below for the reface and another 1500 for brake pads abd probablg 700 for labor. That just a simple brake job
    Sent from my MI MAX 2 using Tapatalk
    Jan 2008
    #1274
    Try rotating tires muna.. then pag nandun pa din check kung pantay ang upod ng pads.. baka may piston na stuck up.. check also mga rubber bushing baka may sira na.. pag warp na disc mas ok na palitan ng bago kesa reface..
    #1275
    i once had my disk machined/refaced. the driver (not me!) did not know what that strange sound was all about, everytime he stepped on the brakes.
    by the time i got to it, putting on the brakes generated a gravel-y sound.
    when we had a look-see, the friction pad was ... absent!
    after several years, the said re-faced disk is still fine. walang kabig, etc.
    just do not go below the prescribed thickness limit.
    Mar 2004
    #1276
    Happens only when applying brakes at higher speeds ... it's not the tires ...
    Apr 2010
    #1277
    actually doc i can only feel the vibration on the brake pedal pero wala naman sya kabig on any sides.
    i always tell my SA to check my brakes. and I do regular tire rotation sa servitek wheel balance included.
    #1278
    Sharing my 2019 4x4 E Hilux. Fitted it with Ironman 4x4 2" lift kit, LineX bedliner, and all terrain tires
    So far enjoying this pick up img_20191219_134553__01.jpgimg_20200117_103716.jpgimg_20191219_110945.jpgimg_20200224_091402.jpg
    #1279
    Grats! What's next?[emoji4]
    #1280
    would be upgrading the sound system, walang tweeter yung stock ng Hilux E. basic sound upgrade lang.
    front - seps
    rear - coax
    spacers, foamring, and some deadening materials.
    will not upgrade the headunit in the meantime para stock looking lang muna.
All New Toyota Hilux
