Good evening guys, who else uses Shell Fuelsave on their thirdy? Any feedbacks? I just filled up with Fuelsave last week, and it seemed smoother than the other variants that I've tried (XCS, Blaze, V-nitro+R, Extreme97) despite its lower RON. I havent computed for its fuel efficiency though, mine averages at 10-11km/L at 3k ODO.![]()
Hi,
Question, kapag bumili ako ng backup camera, pinakabit ko sa toyota. Void ba ang warranty ng electrical?
Thanks
Thanks, sabi kasi sakin void e. Hindi daw kasi Toyota yung camera ko.
Item and install should be from them too, that is a marketing strategy. If you opt to get an after market, might as well let them(outside) install it, di naman po magkaka-problem yan at free pa install.
Drove mine (1.3j) kanina from pampanga to Laguna at hinataw ko, 120+ but not reaching 140 sa NLEX.
I think this vios model can only run very smoothly at 100kms/hr. I also noticed the break is not that good so my advice dun sa mga kapareho ko ng model, maintain a good amount of distance sa sinusundan nyo.
By stable I mean that it doesn't feel any different than our old 2.0 Altis (which I've driven past 200 kph before).
Yes mine is a 1.3 AT.
Has anyone here tried Illuminated (blue interior light) Leg Room installed on his vios? Any feedback please.
I got the same question privateryan. And also napapalitan ba yung color ng stereo?
RE stereo, it doesn't have that option brother. What have you modified on ur vios so far?
Hi guys! Dahil sa Baguio gridlock we just opted to stay in Pangasinan. Drove Jesse for around 550km since yesterday and today driving Manila-Pangasinan, inner cities of Pangasinan, and Pangasinan-Manila. Namali kami ng labas sa SCTEX instead of going to TPLEX we exited in Luisita kaya binaybay namin MacArthur til Urdaneta haha.
And it's just Jesse's 8th day... 😁![]()
Hi sir question lang. Mali ata kasi ginagawa ko sa akin. On uphill, press ko lang pedal to maintain yung target speed then sa downhill, bitaw na ako hanggang marating ko yung flat road then balik ulit ako sa target speed ko.
Dapat pala mag speed up ako sa downhill then sa uphill hayaan ko lang yung momentum? If mag speed up ako going downhill, hanggang sa anong speed? Usually sa 80 ako nagccruise. At kapag uphill naman anong speed yung gagawin kong minimum bago ko ipress ulit yung pedal? Sctex subic din madalas daan ko.
If you want maximum efficiency, instead of maintaining a certain speed, maintain a certain pedal pressure.
Say, you step on the pedal at 1/8th travel. On a flat road, this might be enough to maintain your speed at 80 kph. Maintaining the same 1/8th pedal pressure even on an uphill will definitely mean that you will decrease speed to about 70 kph - just let it happen. Conversely, even with just the same 1/8th pedal pressure, if you're on a downhill, you might accelerate to 100 kph. That's okay too.
For long uphills though, sometimes I apply more pedal pressure (about 2/8 instead of 1/8) to be able to maintain a minimum speed of 70 kph. For long downhills, when I go past 120 kph sometimes I just coast already.
One more tip, when you're about 1km away from the toll exit and you're still going at 80-100 kph, you can coast all the way already. Likewise, if you see that there's a slow car up ahead and you can't overtake on the other lane, instead of braking, just coast to gradually lose speed.
Basta coast as much as possible.
Thanks sir. Try ko yan sa byahe ko ulit lagi akong 13-14 lang at same route ata tayo qc to subic.
