Getspark on other hand is like MSD,mas simple at cheaper.W.12 ignition enhancer - YouTube
Wow, and the engineers at Toyota never thought of this wonderful technology?
when we were younger, we just about tried every other gadget we could get our hands on.. initially, we convinced ourselves it really worked. but after 1 or 2 weeks, the novelty wore off and we decided it doesn't work at all.
another guy puts it better: "if it can't be measured in numbers, then it doesn't work".... words like "feels smoother, sounds better, like new, more responsive, etc...", just don't cut it. heck, i can elicit that feeling in every oil change using the cheapest decent oil in the market..
*uck. I can't believe you aren't banned yet after that GTOil fiasco where dvldoc practically owned you with technical reasoning and data sheets.
So now you have a second product? Bloody hell.. I understand money is money but scamming people? Damn. That's a business I wouldn't want to be in.
For everybody out there who's reading this, take his "credibility" with a grain of salt. I suggest you read back on his previous posts (which aren't many) and you'd plainly see they're advertisement related.
nabasa ko na nga facebook. hanep 100% increase in fuel economy. magpapalagay ako ng 34,500V na 3 phase transformer sa vios ko baka magluwal na ng gasoline to kesa kumunsumo. heheheh.
guys may nag upgrade na ba sa inyo ng audio system?
I would like to have amp, sub and tweeters installed. However, my concern is where the tweeters will be placed. Hindi ba masagwa kung nakapatong lang sa sides ng dashboard yung tweeters?may ng quote na sakin and subok ko na shop na yun. Ang concern ko lang yung pwesto tweeters mas maganda sana just like sa Vios G units.
BTT
anong stock bulb ng headlight ng vios naten ilang watts? plug n play ba yung philips xp kahit sa projector lights?
regarding sa oil, plan ko kasi 1k at 5k mineral oil tapos 10k FS na, pag nag FS ako sa 20k na ulet ako mag change oil? filter and top up lang sa 15k, tama ba? safe nman yung ganung style?!
Gee... so what are you people? Elon Musk wannabes? Har har..
Yeah, "crazy" is a poor term to disguise how unethical your business practices are.
Well, I haven't checked yun Vios namin but if it's anything like the old Vios model, it's a H4 for the headlights and H11 for the fogs I believe. If then so, plug-and-play lang dapat yun mga Philips. The Vios uses a halogen projector housing.. don't confuse it with HID projector housings.
And regarding the oil and interval changes, yes. Walang problema yun. I will like to point out that you might want to flush your oil completely sa 10,000km para wholly fully-synthetic lang nasa loob. Actually, FS can last much longer and the best barometer in knowing when to change is to simply check up on it. You might also want to "top up" on your 15,000km if the oil is more dirty than expected.
Bulbs can be found in the manual. Head Light: HIR2/9012/HB4 bulb - Projector type. H4 - Reflector type. Normal power rating normally ay 55/60watts. Fog Light: H16/5202/H11 bulb 35watts.
About sa oil, yan din plano ko. I think safe naman kasi stated sa manual ay 12mos/10K replace interval, though I assume fully synthetic to. Otherwise kapag mineral oil, every 6mos/5K ka palit.
Update: FC ko ay 9-10km/l city driving G matic. Oil is TGMO mineral oil, 1.5K ODO reading, 205/45/17 rim/tires *32/29psi.
One time full tank ko Blaze 100, I noticed bumaba yung idling (parang nangingining kahit naka neutral at lalo na kapag naka-"D" at full stop yung auto) nya tapos bagsak din yung FC ko naging 9km/l max. Di ako naka-tiis, 1/2 palang remaining, balik full tank ko uli to Shell Nitro+. Yan ngayon yung current FC ko 9-10 driven normally.
I guess the bulb type differs between G and the lower variants. Tama po ba?
Yes, bi-projector yung G. Iisa lang filament ng bulb nya. may shroud sa loob ng lens na gumagalaw depende kung hi/lo beam. yung reflector naman H4 bulb yung gamit, dual filament yan. Thats why 55/60watts ang rating nya.
I am getting a brown 1.3E AT this month. Any recommendation on the tint? OK to have 35% on windshield while 20% on sides and rear? Is visibility still ok on sides and rear view at night time? Thanks in advance for your inputs.
Sent from my Nexus 7 using Tapatalk 4
