Page 34 of 35 FirstFirst ... 24303132333435 LastLast
Results 661 to 680 of 691
    Nov 2013
    #661
    Good day mga sirs,
    Ask lang po sana ako ng opinion nyo regarding sa problem ko sa vitara escudo AT (sidekick). Ang nging problem po nung sasakyan is yung crank shaft pulley need na pong palitan kasi nag wear-off n ung rubber nya in between plates. So last week after sya napalitan kila Mang Rod (Filmars) ng crank shaft pulley at the same time inayos na rin daw yung timing, nung na drive ko na, napansin ko na parang biglang mag slowdown even if nkakatakbo na ko ng mabilis. Parang bigla na lang nhihirapang mag accelerate. Bago napalitan yung pulley, oks nman yung acceleration nya, so bumalik ulit ako sa Filmars at inadjust ni Mang Rod ung acceleration cable, sabi nya yun lng daw ang pwede nya mgawa dun since AT daw kasi. After ng adjustment, ng drive ulit ako at gnun pa rin ang result nya. May kinalaman kaya yung timing sa pgbago ng takbo nya? Any inputs po regarding my problem mga sir? Thanks!
    Nov 2013
    #662
    Good day mga sirs,
    Aug 2012
    #663
    Good morning, tanong ko lang how much ang water pump and timing kit for 96 vitara g16b? nasiraan ng water pump and isasabay na ang pag palit ng timing belt. :D
    Aug 2012
    #664
    Quote Originally Posted by Ramil Baytion View Post
    ok na mga sirs, napalitan na
    #665
    good day mga sir hingi lang po sana ako ng input kung anung possible na tama nung vitara JLX 96 model namin, we purchased the car as 2nd hand at interior and body is flawless reason why we did not hesitate to buy the car . when we did a test drive it was running good,as as we brought it home we noticed that the water from the radiator was almost empty the engine is overheating we brought it to the mechanic and was informed that it is a loose compression issue and the water is also mixing in with the fuel,they had to do a top overhaul change gaskets change radiator as well they also had the engine waorked on a machine shop,after 4 days they were able to accomplish the repair but there still issues on the engine the 3rd cylinder from the front is not working,we had it checked again at reys electrical found out that all the plug wires has electricity,also one issue is when we are driving uphill wlang hatak sa 2nd gear and the following gears kahit nakabwelo na,we need to stay at 1st gear para lang makaakyat,hingi lang po sana ko ng input kung anu po kayang reason kung bakit hindi gumagana yung 3rd cylinder at bakit ayaw humatak sa 2nd gear pag akyatan na,im planning to change the spark plugs muna but im not sure if it will fix it,anu nga po palang spark plug ang bibilhin ko TIA mga master NOOB kasi ako sa sasakyan
    Dec 2012
    #666
    I am planning to buy a Suzuki Vitara JLX MT 1996 * Php 135,000
    Seems ok ang condition ng interior at exterior.
    Scheduled for test drive tom...
    What do you think of the price considering it is already an old vehicle.
    Thanks,
    Edd
    Sep 2011
    #667
    sir swertehan ang pagkuha ng vitara sa panahon ngayon, kung kakilala mo buyer mas mabuti para malaman mo totoong history ng bibilin mo. Pero kapag naka-tiyempo ka ng maayos pa na vitara, you'll be satisfied sa performance. Almost 4 years na sa akin nakuhang kong vit at napaka-low maintenance parang hindi nasisira, minor lang mga pinaayos ko. Nagamit ko na sa mga off road at long distance travel like Baler, Bolinao,... Hindi naman ako nagkaproblema sa lahat ng travel ko.
    Dec 2014
    #668
    Hi Guys,
    Im planning to get a Vitara first Gen as a first car. May ma recommend ba kaung unit that is within 120k Budget. Metro Manila po. Salamat
    Dec 2014
    #669
    try sulit olx bro. im selling mine but its a 2001 jlx model. At vitara2014ayosulit1_004.jpg
    Dec 2014
    #670
    Quote Originally Posted by Miggy Calimag View Post
    Hi Bro, How much yang auto mo? And san location mo? Email mo ko sa pjmdimailig*gmail.com
    Dec 2012
    #671
    Ask ko lang kung anong tire size ang kasya sa stock height ng vitara? Thanks!
    Apr 2014
    #672
    Quote Originally Posted by kopi View Post
    Sir san mka bili lifter ng vitara jlx96?
    Gusto ko ilift ksi yng sa amin.
    Jul 2010
    #673
    Di ba mahirap parts ng vitara sir?
    Fuel consumption?
    May 2015
    #674
    Stock Vitara setup would allow us much as 235/75r15 or 29" Tires without rubbing. You can fit 30x9.5r15 but it will rub against the plastic bumper. You can have it skillfully cut by your seasoned latero and the cut would be negligible.
    Quote Originally Posted by Paul77 View Post
    Boss,
    Pag 2" lift lang po marami pong paraan.
    The pricey path:
    1) Ironman offers a 2" kit comprising of coils and springs only. Set is around 35K.
    2) Old Man Emu also has this kit for 50K.
    The Budget path:
    (((IF You want a suspension lift))
    1) You can simply go for 2" coil spacers (rubber or aluminum). They will increase ride height but will not give any extra articulation the way longer coils will.
    2) You will need to put 2" extension brackets on your stock front struts (front shock absorbers) to compensate for the 2" additional height of the coils.
    3) You will also need to get longer rear shock absorbers. There are a lot of affordable options for this. Stock shocks have a length of 19". So you need to get 21" or 22" long shocks. KYB Premium is the most affordable.
    4) You will also need to adjust your camber alignments so you need to get camber bolts.
    Estimated cost: 15K
    Another option is a 2" Body Lift only. This does not alter any of your suspension geometry. All it does is lift your car's body 2" above the chassis giving a visual lift only. These are normally done to fit larger tires to prevent them from rubbing against the fender walls. But it gives the illusion of a lift.
    Estimated cost: 6K
    Hope this helps...
    Boss,
    The pricey path:
    The Budget path:
    Estimated cost: 15K
    Estimated cost: 6K
    Hope this helps...
    May 2015
    #675
    Quote Originally Posted by nujbc11111 View Post
    Fuel consumption?
    Vitara parts are not hard to come by. They are only expensive compared to Toyota parts. But they are easily sourceable.
    FC for a well maintained stock would be 12kms/ltr city driving and 16kms/lts highway... FC for Modified rigs with chunky tires would be a fraction of those numbers
    Fuel consumption?
    May 2015
    #676
    Quote Originally Posted by dax18 View Post
    Hi Dax18,
    Were you able to sort out this problem already?
    Mar 2005
    #677
    Quote Originally Posted by Zooker View Post
    Boss,
    The pricey path:
    The Budget path:
    Estimated cost: 15K
    Estimated cost: 6K
    Hope this helps...
    Boss,
    The pricey path:
    The Budget path:
    Estimated cost: 15K
    Estimated cost: 6K
    Hope this helps...
    Hi Zooker,
    I want to lift my suki '97, do you have any recommendation where to buy this parts locally?
    May 2015
    #678
    Quote Originally Posted by avv View Post
    Hi Zooker,
    Hey Man,
    For the ARB kit, you can go to RATS4x4 along Katipunan.
    For the Ironman kit, you can go to MONSTERWORX Steel Fabrications in c5 Extension near SM Sucat and look for Raymond Rivera...
    If you wish to ask for the cheaper alternative I posted in the previous messages, send me a PM as there are many things to consider when you go that way.
    May 2008
    #679
    Sir zooker possible ba iconvert sa diesel engine ang vitara while maintaining its 4x4? I understand that the Mazda RF engine is compatible, but how about the transmission? Thanks in advance!
    Mar 2016
    #680
    Meron kayong alam na head unit na touch screed with nav para sa suzuki grand vitara 2015? Hm? Tnx
GEN I Suzuki Vitara 88-up [merged]
