Results 421 to 430 of 691
October 1st, 2010 01:53 AM #421
baka may isang gear sa loob ng nasira kaya di gumagana ODO. dati benz ko ganyan din, the option from the forums was to find a gear from RC cars, that has the same teeth count, or buy the whole assembly. i just left it as is, kasi when i opened the meter, durog na durog yung gear impossible na mabilang pa kugn ilan ipin nun.
- Jan 2010
- 3
October 1st, 2010 02:07 AM #422Ganun ba sir, i'll try to have it opened muna. Parang complicado ayusin ah. Ang mahal naman ng whole assembly kung bnew, sana meron surplus pa.
- Jun 2008
- 24
October 1st, 2010 02:20 AM #423regarding oil seal ng differential eto inabot ko chief..
oil seal - 250
labor - 250
gear oil - 400
solve na...
October 1st, 2010 02:32 AM #424
- Jul 2010
- 109
October 1st, 2010 12:32 PM #425
October 1st, 2010 08:25 PM #426
yes it's also the hand brake warning lite
it's half full, so pag nalubak ka gagalaw yung fluid mag iilaw yung warning light.
kung mababa fluid level mo at walang tagas sa linya baka manipis na pads.
dun sa hand brake lever, may switch dun, pag naalis mo yung center console makikita mo yun baka maluwag, but that rarely happens. kung maluwag no contact, hindi iilaw.Last edited by impulzz; October 1st, 2010 at 08:28 PM.
- Jul 2010
- 109
October 4th, 2010 11:51 PM #427
October 8th, 2010 07:55 PM #428
don't forget to have your brake pads checked, baka manipis na, kaya mababa fluid
- Jul 2010
- 109
October 13th, 2010 07:11 PM #429Would it be an easy/safe task to replace the bulbs behind the dashboard gauges panel? Ang dilim na kasi kaya hindi na umaabot yung ilaw sa bandang temperature gauge.
October 13th, 2010 08:11 PM #430
madali lang naman, total of 8 screws to remove. then there are 2 wiring sockets to remove and the speedometer cable. kaya madilim yung sa may temp gauge kasi may pundi siguro na rice bulb.
2 peanut bulbs at 2 rice bulb yan. the rest are for the warning lights. while you're at it, clean the inside too.
Kenn, bouncing na din ba yung speedo needle mo at low speeds? like 20 to 40 kph.Last edited by impulzz; October 13th, 2010 at 08:26 PM.
the winner is selling it :twak2: 350k daw i already messaged him haha. it's just a free car so i'm...
Bestune Pony mini EV
