Page 19 of 31 FirstFirst ... 915161718192021222329 ... LastLast
Results 181 to 190 of 304
    #181
    Not really being optimistic or pessimistic about it. Just reporting my personal experience with 3 CVT cars from different brands and different ages and comparisons with ownership of conventional AT and MT cars.
    How old was your 3 when you got it, sir? Did the transmission see any prior service? CVTs bought bnew, I presume?
    #182
    Meron ba CVT umabot na past 500k like regular AT?
    Ang point lang ni Trav, CVTs are not fully proven technology. The design of constant metal-to-metal friction is a design flaw on his engineering perspective. For regular AT it's only fluid friction in the torque converter and some clutch packs, there are less metal-to-metal contact that could wear. Even on MT's you will eventually replace the friction material(clutch or even flywheel) because they are wear/friction parts, but it costs less because the technology exist since the invention of a car.
    Dapat siguro for consumer's peace of mind gawin wear item ang CVT belt, replace every n kms.
    #183
    Great idea, sir![emoji106] Dealerships must be equipped & trained.
    #184
    It will happen only when you exceed the maximum specified speed of the car with CVT for a prolonged period of time
    I guess you can compare the maximum speed specified for an AT car from a CVT to get an idea which transmission is more robust
    Typical CVT max speed specification is 167kph..drive that transmission to 180kph and above for an extended period of time..expect the end of it soon
    Can you share an article which states that a CVT tranny has maximum specified speed of 167kmh? It seems to be a bit low knowing that some cars with CVT has more than 150hp.
    Even Subaru's non-turbo cars with CVT is rated up to 200 kmh. Some turbo Subies with CVT can go up to 250 kmh. Yung ASX I drove up to 180kmh but it seems it can do faster but the stock Yoko ASPEC tires seem to lose grip past that speed.
    Anong exact extended period of time? 1 hr-2 hrs na 180kph na diretso? Saan and sino nakakagawa nun? Serious question.
    I drove flatout at SCTEX (NLEX Interchange to Floridablanca exit) and it was just around 15 minutes. I was doing between 160 to 200 with a short burst to 220. I have not done it again.
    Did you drain & fill at least twice, bai?
    Fusion R only does a single cycle of drain and refill. That's what they do for their customers. You can pay them again if you want to do it twice but for that cost, you might as well do a full dialysis which requires 13L.
    Jun 2013
    #185
    But then you’re going prolong the life of a CVT, it will be one more reason why you shouldn’t purchase a brand new car. Ayaw ng mga car companies yun. Less profit. 😂
    #186
    Can you share an article which states that a CVT tranny has maximum specified speed? Typical maximum is only 167 kmh? That's peanuts for some new CVT cars now.
    Thing w/ full dialysis, OCD kicks in....haha. 1 has to be sure the equipment is evacuated of whatever fluid it previously serviced....I prefer drain & fill...twice or thrice w/ some good run in between...Insane, I know.[emoji16]
    #187
    Regarding this "speed limit" of the CVT, alam ko din depende na ito sa design ng transmission. Dati walang Medium or High Torque CVTs kaya di nila kaya but nowadays nagdevelop na sila for larger engine sizes/power output.
    (JATCO) Archives of Past Exhibits: JATCO - MarkLines Automotive Industry Portal
    (AISIN) Archives of Past Exhibits: Aisin Seiki - MarkLines Automotive Industry Portal
    Mas mahirap lang hanapin sa listahan mga Aisin transmission products kasi di lang CVT ginagawa nila. hehe.
    #188
    If you do the dialysis at Motor Image, you'd be sure that your Subie will use the right fluid. Motor Image charges around 17k for the CVTF dialysis method.
    Some groups in the US suggests another drain & refill with a month's interval after the first one. It would use up between 12 to 13 liters of CVTF for both process.
    Dec 2013
    #189
    The jatco cvt7 jf015e on my mirage was designed for 150hp. The mirage only has 80 or so hp. I think it will do 150k kms just fine (with proper maintenance).
    #190
    Why not DIY drain & fill?[emoji4][emoji106]
ATF fluid used in CVT Transmission
