Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
    #21
    subukan nyo po ang spring ng rear trunk.
    and i suppose you already checked the length of the exhaust system..
    saayyy... does the sound quality change when somebody is seated on the rear seat?
    #22
    Had that checked too and it was fine. The Mazda 3 uses 2 small shock absorbers for the trunk lid, no leaks at all.
    Apr 2013
    #23
    Bro jut ,my wild guess,paki tsek mga welded part , baka may natanggal na hinang.
    Oct 2009
    #24
    ganyan sa akin binaklas ko buong likod ng compartment ko at upuan sa likod para ma trace ko kung saan nanggagaling ung rattle sound.sa akin naman pag dumaan ako sa hindi aspaltado na medyo may lubak,,lalo na kung mabagal ung takbo ko arround 20-30.naririrnig ko palit ako ng shock.at mga rubber bushing walang epekto nandun parin..
    palit ako ng shock mounting bushing.cost 150 pesos at 10 washer. ayun nawala ung rattle sound.,
    mga 5 times akong nag baklas ng shock ,bago ko na trace ang sira niya..
    honda vti sa akin
    #25
    Quote Originally Posted by cardict View Post
    Which welded part should I have checked? Hindi ba buong panel naman yun so walang welding?
    Quote Originally Posted by jaypee10 View Post
    honda vti sa akin
    Swerte ka cuz it was just a bushing problem. Natry ko na palitan yung akin but same pa rin may sound pa rin.
    Oct 2009
    #26
    na try mo naba sir suutan ng hose ung magkabilang dulo ng spring..
    #27
    Not yet, but I had my coil spring checked and it had no broken bits.
    #28
    Finally solved my rattling!!! I noticed that even though there's a sound when my brakes are on, it sounds different compared from when I'm not stepping on the brakes.
    Brought the car to Cruven Makati and asked them to check the brakes. They disassembled the caliper assembly and found that the brake pad was not snugly
    fit into the housing. They welded the pad's edges to make it fit snugly. And poof! No more rattle!
    Problem solved for only 350 pesos. Unfortunately I also spent 2.2k for new stab links, but that's part of the learning. Thanks to all those who chimed in their suggestions. [emoji106]🏼
    #29
    Maganda pala talaga sa Cruven
    #30
    Alam kagad nila yung gagawin when I pointed out that it was a brake issue. I'm not sure if other shops would've been able to diagnose it correctly and weld the brake pad edges as a solution. Yung ibang shops nga parang wala namang welding machine though of course baka di ko lang nakikitang ginagamit.
    To be fair though, if I didn't tell them of my observations with the brakes, I'm sure they would've thought that the suspension was the culprit as well. Inexplain ko na kagad that I've changed all my suspension bits so they should look elsewhere.
Unknown Kalampag (Not Suspension-related)
