Results 1 to 10 of 19
December 26th, 2019 02:07 AM #1
Ka kapalit pang ng brake pads ng disk brake sa harap a few weeks ago. Before palitan may mekaniko na nag sikip ng brake para, then dinala namin sa ibang mrkaniko at pinalitan ng brake pads, hindi ko alam kung niluwagan.
Any way this past few days sumisipol ang brake sa harap. I don't know kung natanggal ba yung brake pads or may mali? Can it be verified in this picture? And is it safe to drive?. Kailangan kasi gamitin.
- 52,842
December 26th, 2019 02:10 AM #2at these angles, i don't see no brake pads.
i hope i'm wrong.
because if i am right, you're probably gonna need some machining to bring your rotors back to snuff.
and no.
it is not safe to drive without brake pads. there won't be enough friction to properly stop the venicle.Last edited by dr. d; December 26th, 2019 at 02:31 AM.
December 26th, 2019 04:32 AM #3
agree with doc, its not safe and not advisable to continue using the vehicle. without brake pads, not enough friction to bring the car to a stop. iinit din or worst magbaga ang rotor at brake calipers kasi metal to metal ang magkadikit. kakayodin rin ng caliper yung flat surface ng rotor disc so need ng machining or kung malalim ang tama baka hindi na mahabol ng machining at need palitan. bale ang consumables ay yung brake pads, not the brake rotors and calipers
- Oct 2006
- 5,745
December 26th, 2019 05:13 AM #5From the looks of it meron naman. If there were none, your brake rotors would be heavily scoured by the piston/s. Also disc brakes are self-adjusting, unlike drums. Di siya pwedeng sikipan/luwagan manually. You can back up the pistons (e.g. when you have to fit new pads), but the moment you step on the brakes, babalik din yan.
December 26th, 2019 06:27 AM #6
What do you mean sinikipan or niluwagan ang preno? Baka Stucked up na piston mo? Kaya napudpid agad?
December 26th, 2019 06:49 AM #7
Ok thanks I'll ask my brother in law to look at it. If it doesn't have brake pads I wouldn't be able to touch the brake because of heat of metal to metal, right? Malamig naman sya after a short drive, I was able to touch it.
December 26th, 2019 06:56 AM #9
Maybe I'm wrong about sinikipan, baka yung drum brake sa likod yung sinikipan? Di naman sya stuck up kasi na drive pa namin ng about 10 minutes. I asked my wife kung ano feel nya sa preno kung hindi ba kumakagat, ok naman daw preno. I'm just concerned sa sipol na naririnig ko.
- Oct 2006
- 5,745
December 26th, 2019 07:15 AM #10
In our case, the thermostat was removed. But yes, if the thermostat is stuck open, it might show...
low idling during cold start
