Results 1 to 10 of 40
March 27th, 2012 12:54 PM #1
help mga sir
been dealing with this problem for awhile now. eto yun mga nacheck ko and nagawa
rotors - ok pa naman daw sabi ng mekaniko smooth pa. kakapalit ko lang 1 year ago
brake pads - bendix general ct (sabi ng isang mekaniko na pwede eto ang culprit pero hindi niya ko masagot pag tinatanong ko kung bakit yun kabilang caliper hindi maingay)
nagpalit ng surplus caliper - nawala ng one week then bumalik ulit ang grinding/screeching sound
caliper pin - pinalitan ko bago. nawawala then bumabalik ulit
pag madiin ang brake wala pero pag yun padampi dampi lang. ang lakas ng tunog/
naiipit talaga ako dito sa problem na to. dami ng napalitan hindi parin nawawala hehe
siguro pag may budget na ulit papalitan ko rotor or pads na din. (maybe ferodo brake pads) kung may mahanap.
car is sentra series III
March 28th, 2012 03:07 PM #2
i heard or maybe even read somewhere that bendix pads are quite noisy, try changing pads first, hth
March 28th, 2012 07:51 PM #3
nag tataka lang ako bakit yun kabilang side hindi umiingay. eh pareho lang naman silang bendix
- Jul 2011
- 1,711
March 29th, 2012 05:57 AM #4Ganyan din ung naging case ko sa RAV4, pag mabagal ang andar ko at nag brake ako maingay ang brakes, nung pinatignan ko sa mekaniko ung apat na brakes makakapal pa ung brake pads. Ang sabi ng mechanic matigas daw kasi ung brake pads na nakakabit kaya ganun, kung gusto ko daw tahimik palitan ko ng madali maupod na brake pads.
- Jun 2005
- 3,774
March 29th, 2012 08:45 AM #5had the same problem with my vios while using bendix general ct. lilinisin yung pad, mawawala ang sound pero babalik after 1 week. 1side lang din anh tunog.
ang ginawa ko, pinalitan ko bagong brake pad. bendix genetal ct pa din pero yung may canal sa gitna. yung screaching noise is caused by dust na nabubuo in between pads and rotors. change it sa may canal para may napupuntahan yung dusy at di naiipit sa rotors
March 29th, 2012 09:10 AM #6
i am using din bendix general ct, but on slotted/drilled rotors. i am not a racer, pero yun na rin kinuha ko for the benefit nga na it will sort of clean your pads as you break. though it will lead also to a bit shorter pad life coz of the slots... minimal issue lang naman as the general ct's are relatively cheap - P680 to P750 a pair lang. as the ts said screeching/grinding sound... most probably brake dust nga ito. you can try and follow sirkosero's advice above.
March 29th, 2012 12:32 PM #7
ahh kaya pala pinalitan ko na pins,brake caliper assembly..bumabalik parin. ganun ba talaga ka ingay yun.
nadala ko sa wheelers. yun nga sabi brake pads and yun din sabi nung isang tumingin sa ibang shop.
*sirkosero
2 klase ba yun general ct? san kayo nakakuha?
meron ako gusto i-try ferodo zero kaso yun natanungan ko na shop sa banawe by order daw yun.
March 29th, 2012 12:34 PM #8
natatandaan ko na paps na may canal din yun bendix na nakakabit sakin ngayon.
March 29th, 2012 03:19 PM #9
your brake rotors might be glazed and it causes groaning, grinding or screeching. try having your rotors deglazed or resurfaced. if you have them resurfaced, make sure you wash them with warm soapy water before reinstalling to the car. if the pads still has a lot more life left to it, wet sand it down to remove the glaze that might have transferred to the pads. why only one side you may ask? maybe the other side is not usually parked beside a building. the other side might remain dry most of the time whereas the other side might have been more exposed to the elements of weather
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
